Avaya 4610SW IP Phone Logo
Posted on Apr 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Commands for forwarding call to mobile phone - Avaya 4610SW IP Phone
Anonymous
Level 3:
  • Master 906 Answers
  • Posted on Jul 29, 2010
Anonymous
Master
Level 3:
Answers
906
Questions
0
Helped
308516
Points
1636
Link
Kindly refer to above link for Avaya Manual to know how to activate various phone features.
Thanks.
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
1helpful
Only rings 3 times then transfers to another ext.
Mitel call forwarding is a double-edged sword. It can be controlled by the end user via user-programmed forwarding and it can also be controlled by the system programmer via system call rerouting. User programmed forwarding OVERRIDES system programmed 1st alternate, but does not override the 2nd alternate reroute destination (if 1 is programmed). Try un-forwarding the phone - if still no joy then contact the system support person. Hope this helps. (User-programming commands are initially defined by the system support people when the system is initially installed, so I can't tell you how to do it... you'll need to know what the key commands are (or unforward using the Superkey function if provided).
How do i do call forwarding my phone is broke needing to forward it to another #. my phone is in several several pieces my phone is boost mobile forwarding it to a sprint #
Thanks for visiting FixYa!
What you are asking is, can you remotely activate call forwarding on your Boost Mobile account.
You can't do anything remotely, but if you call Boost Customer Service, they should be able to do it for you.
Contact Boost Mobile By Phone
Business Hours
4am PST to 9pm PST
7 days a week
General Support
1-866-402-7366
2answers
Hello I have a KX t7730 with 4 lines installed in it. the problem is that if person X phones and i am on the line speaking with person Y, than person X go's into voice mail instead of being "dragged " to a...
My office phone is set to Call Forward No Answer to Voice Mail.
I'm guessing that you are learning the difference between the TA series and the TAW or TDA series. Call waiting is programmed from a CW code dialed into the intercom (ie 7311 or *7311) and call forwarding to VM is programmed by a 71x or 710x or *710x command. In a TD TDA or TAW system, you get CF BUSY, CF NO ANSWER, or CF busy/NA.
In a TA you only get CF ALL, or CF Busy/NA.
So, if someone rings your phone while it's busy, there is no indication, just an immediate forward if that feature is set.
Carl
1helpful
Our Panasonic KXt7710 Rings twice then diverts to a mobile number. How do I stop this
This was set up with Call Forward Off Premise. In a TA series, it's a 713+ command.
It's cancelled by dialing 710# on the intercom.
Carl
I am having a problem, I to would like to forward my ext to my mobile phone, or possibly just call my mobile as a differant ext. Is there anyway to do this from the partner 18D phone?. Any help would be...
In order for a Partner to forward to an outside cell, the processor needs to be an R6 or higher.
Is yours? If you press Feature 59 from a display phone, it will tell you what release it is.
If feature 59 doesnt display anything, it is way older, and will not work.
1helpful
Call forwarding
The 50 command is for call forwarding of an individual phone, not the incoming calls. There are several conditions that have to be met to make forwarding work. First, you need your ICD group extension. It's generally 600, but we use 100 or 199 or 200 sometimes. The command is in the back of the Operations Manual (OM) and it is in the form of (assuming 600) *71416009+number#. *7140600 cancels.
http://www.public.carl.airpost.net/TDA/200_TDA_OM_06-121.pdf
Here's a copy of the manual, just in case you don't have one. Page 192 shows the sequence. You might also look at *710 command on the same page for setting forwarding. It is quicker than the 50 commands and sets the status of your FWD/DND button.
Carl
Zero Rings during meetings
With either a Do Not Disturb (DND) or Call Forward all calls command. On a TA-824, DND is set up with the command 714# on the intercom. It will light the DND button. It's cleared with 710#. There is no function to the button, ie you can't push it on and off. If you have voice mail, you can set it to forward all calls via the 711 (vm ext) #. It will blink the FWD/DND button.
As an aside, 7341# stops paging to the phone. 7340# brings it back. Again, these are TA-824 commands.
Carl
Changing number for call fwd on KX-T7630
This is against my better judgement, but try this link.
http://www.microtelcommunications.com/linked/tda_operating.pdf
BEFORE YOU DO ANYTHING, PRESS PROGRAM AND THE BUTTON AND WRITE DOWN WHAT IS THERE.
Now you have a manual. Look at the *7 commands on page 191. My guess is the installer put *714x commands under the button, but he may have done some 44 commands via personal programming. You did write them down? The 3rd piossibility is that it references a bin that is programmed as a mobile number...you can assign any 3 digit number in the universe of 100 to 699
as an ICD number that forwards all calls to an outside number.
Anyway, please acknowledge that you got the pdf and I hope it works out for you.
Carl
Top Avaya Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
