Price of Canon IXUS 80 IS ranging from $280 to $325
check this Link
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
I have read that there seem to be many issues with no display on the LCD in playback or photo mode. What can I do to get this resolved? Thanks you. Greg
SOURCE: Can the canon ixus 80 is be used as a webcam?
It may be able to be used that way (but its pretty iffy)...you would have to have to have a computer with an RCA-type video in jack (or an installed TV tuner card with the same RCA-type video in jack).
And if you have that setup on your computer, then you could use the AV cable that is supplied with this camera to send video out (either what is being shown on the screen in shooting mode, or already taken pictures/videos in playback mode) to your PC.
You would then need to point whatever software you are using to broadcast your webcam stream to the "video in" jack as the source of your webcam video (if it even allows for that option).
If you can do all that, it MIGHT be possible, but its probably a pretty long shot.
SOURCE: hi im using a canon digital ixus 9515 camera. can
This camera is designed to store images and videos to a memory card, not to stream them to a computer. It cannot be used as a webcam.
SOURCE: canon digital ixus 850is card locked! message
.....Open your memory card........Adapter And see There IZZ a ThiNg named Lockand UNLOCk That!!!! i guEsS that woULd Work.....
Testimonial: "many thanks for unlocking my card Is is an 8g card expensive for a pensioner. it had just a few photos on it. Thankyou again Peter"
SOURCE: HiI have a Canon IXUS 80 IS digital camera. The
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
