Lexmark X75 All-In-One InkJet Printer Logo
Question about Lexmark X75 All-In-One InkJet Printer
I need a power supply cord for lexmark x75
Posted by kj7faith759 on
Anonymous
  • Official Brand Answer
  • 3,344 Answers
Hello. Lexmark can better assist you with your request for the power supply cord for your Lexmark X75. You can contact them at 1-800-LEXMARK (1-800-539-6275).
Posted on Apr 07, 2010
Power for the printer has failed
Please go through the following checklist to identify and fix the problem:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Am look for printer cord for an lexmark x75
I had that same Problem. I need the Power Cord, and Power Supply, that came with it. I called Lexmark, told them what I needed, and I receivec it, within two days.
I also needed the USB Cable, that connects to the computer. I found that at "Amazon.com." very cheap.
Have lost my power cords for the x75 and need to know what I need/
Just contact Lexmark technical support to request for the power cord for your Lexmark X75. When calling support, you will be asked for your printer model and the serial number. Thanks.
Lexmark x75 all in one. Started with communications device error. could not print. went through troubleshooting-still wouldn't print. started printing randomly(not initiated by me). Couldn't clear print...
Hi. That's quite a problem you have there. Have your attention first on the power supply. It does get hot but it's unusual if it gets very hot. Take out the power supply (the black box behind the printer where the power cord is attached). Check the power specifications. Most of the Lexmark power supply has input ranging from 120-240 Volts and an output of 30 Volts. Make sure you're plugging it in the right voltage range. Check if you're using power surge protectors or power strip, disconnect it and plug directly into a properly grounded wall outlet. Power surge protectors can also draw power away from the printer. When everything's well, try printing again. Hope this helps.
I have misplaced the power cord for my x1200 model printer
You may check on ebay for a power pack, otherwise you'll have to buy one from Lexmark or someone who sells Lexmark supplies.
Lexmark X75
to RickwNJ,
The lexmark web site has the drivers, but not for Vista, iirc.
Best wishes
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Marvin
Marvin
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
