Hi there
ERROR 1203 LEXMARK ERROR 1200
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted by LEH at 5:39 AM
Labels: Lexmark x
1 comments:
MarCrazy said...
Lexmark X4270 Error 1200 Fix - Use link below to see how to fix
Text version below use link above to see pdf with images.
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Is it a refilled cartridge or brand new genuine Lexmark cartridge? Have you tried removing the black cartridge from the printer and cleaning the nozzles with a damp paper towel? The cartridge may not be seated properly in the carrier or just needs cleaning.
