Question about HP LaserJet 4 plus Printer
Laserjet4 50 intervenire - HP LaserJet 4 plus Printer
Posted by brunopotito on
Anonymous
    Novelist:
  • 91 Answers
X FUSER ERROR A fuser error has occurred. 1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Posted on Apr 07, 2010
MW8108P 1100 Watts Microwave Oven
Aqu? est? la conexi?n al manual para su horno; http://www.servicemanuals.net/freemanuals/MW8104SSIB.pdf Puedo s?lo lo encuentra en ingl?s, si usted desea traducirlo entonces el mejor sitio es; http://www.freetranslation.com/ Aqu? est? la conexi?n para el sitio de emerson si usted desea contactarlos; http://www.emersonradio.com/main.html No utilice su horno con una puerta da?ada. Potencialmente le herir? o su familia, da?ar? posiblemente otros art?culos el?ctricos o empezar? un fuego, y emitir? quiz?s una se?al ilegal de la radio que puede intervenir con otras transmisiones. Obt?ngale repar? o reemplaz?. Espero que esto ayude:) Here is the link to the manual for your oven; http://www.servicemanuals.net/freemanuals/MW8104SSIB.pdf I could only find it in english, if you wish to translate it then the best site is; http://www.freetranslation.com/ Here is the link for the emerson site if you wish to contact them; http://www.emersonradio.com/main.html Do not use your oven with a damaged door. It will potentially injure you or your family, possibly damage other electrical items or start a fire, and perhaps emit an illegal radio signal that may interfere with other transmissions. Get it repaired or replaced. I hope this helps :)
Apr 19, 2007 | Emerson MW8108P Microwave Oven
HP LaserJet 4 plus Printer Logo
475 people viewed this question
Ekse
efs_perpends
efs_perpends
