I just installed system suite 9 & now my desktop is not showing up at all, i cant refresh or nothing, this happened as soon as i had installed it. How can i fix that?
A solution to that is to install Windows Vista Ultimate on top of your old vista installation. Just insert your Vista DVD and restart your computer. And simply follow the instructions for the installation.
If you place your Win7 disk in the DVD drive boot the laptop from the disk and choose to install a new system. Follow the menu and prompts. When it has installed download the drivers from Acer.com otherwise you will get problems. Hope that helps.
does the cd show up " ICON if not down load this nd run it - it will reset the cd rom in the registry and 99% of the times fixes it after you run this file reboot PC
Hi! if you are not opening mail, then how are you asking help! ok then, make sure of deletion of trojan virus from your system, apart from updating of java and others such as flash players of browser, check for registry keys also and apply for add-on's blocking and apart from these, ... try to check of opening in chrome / fire fox in order to make out error in browser compatibility if possible and have fine..
These suites get way to crazy because of how they try to force people not to copyright them. Within your install process a rootkit was installed and it wont come out of your computer...do what I did...
Go to www.Myspace.com/KyleGallas to watch a video of a Custom Gaming Computer with all the must have security features...The PC has like $4,000 retail for like $659. It comes with a ton of extras like 133 Nintendo DS Games, Fallout 3, Adobe CS4, MS Office Ultmate 2007, Roxio Ultimate 2009...and more...Nothing is trial-ware but yours forever.
Refresh the USB ports: 1. Right click MY COMPUTER 2. Select PROPERTIES 3. Select HARDWARE 4. Select DEVICE MANAGER 5. Select UNIVERSAL SERIAL BUS CONTROLLERS 6. Right click on each USB CONTROLLER and select Uninstall 7. Uninstall all entries 8. Reboot your computer 9. As your computer re-boots it will reinstall all USB connections it detects THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB card reader If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Two things to try. First, uninstall SS9 completely> restart> disable any network access> turn off automatic security settings in vista> reinstall SS9> restart> enable vista security settings> reconnect network> run update. Firewall and AV should work now. If this does not work then try the same steps above but do a selective install and uncheck firewall. When install is complete and you are connected to the network then go into control panel and, using the system suite repair function install firewall. Good luck.
