I bought a 2GB micro
SD Card to get my pictures from my phone to my laptop and the card doesn't seem to be working
If you are unable to use your memory card, your LG CU515 has a data cable connection which supports charging and mass storage mode.
Once you connect your phone to your PC with this cable, you should be able to transfer your pictures.
USB Connection Mode:
You can transfer files between a compatible PC to
the memory in your phone using the Mass
Storage. When you connect the phone to a PC
using the USB cable, this will be displayed as a
removable disk through Windows Explorer.
After connecting your phone to your computer with the data cable on your computer, click: START > Computer > and look for the phone in the list of storage devices.
On your PC, double click on the icon that identifies your phone - and locate the folder where the picture's on your phone are located. Then double click on your picture's folder on your PC. Simply drag and drop the pictures from your phone to your PC.
If you do not have a Data cable, one can be purchased either at your local cellular retail store or on eBay:
Click on this link:
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=lg+cu515+usb+cable&_sacat=See-All-Categories
Just in case you need it, you can view your user manual at this link:
http://us.lge.com/download/product/file/...
SOURCE: memory card
connect the card in memory card reader and got to mycomputer-->right click-->manage-->disk management. see weather you memory size is correct or not if its different right click the memory card and delete the partation then create a new partation
i was done this to my san disk memory card
SOURCE: Installing a 2GB PNY Micro SD Card
Only the Sprint version of this phone supports memory cards over 1 Gigabyte. Sorry. But if you have a Sprint phone comment back to me using the comment box below. Thanks.
If you don't have a Sprint phone you need to acquire a 1GB card and use that. Hold on to your 2GB card as it will be usable when you upgrade at the end of your contract period.
Regards,
Worldvet
