Question about Kitchen Appliances - Others
I have a equitytime thermometer and can't find the instructions for it. I just changed the batteries and can't get the outdoor to send a signal to the indoor unit. where can I find the instructions for a equity mod#31215B wireless thermometer?
Anonymous
    New Friend:
Take the batteries out of both units (the base and the outdoor thermometer). Put the batteries back into the outdoor unit, and then put the batteries back into the base unit. This worked for me.
Posted on Sep 20, 2010
Lidl/Auriol Z31601B-RX weather station
1 Weather station
1 Outdoor sensor
2 Batteries, type LR06, 1.5 V
2 Batteries, type LR03, 1.5 V
1 Set of operating instructions
Note:
First insert the batteries in the outdoor sensor, then the weather
station.
http://www.lidl-service.com/static/58242588/91679_en_da.pdf
Jan 02, 2018 | Televison & Video
31215 Wireless Outdoor Thermometer manual
With mine, the battery in the weather station has to be changed twice as often as the one in the external unit. Even though the display on the home unit is visible, it doesn't have enough power to pick up the signal from the outside sensor.
I am not familiar with yours, mine is national Geographic.
The reviews on yours are very mixed, but lots of questions are answered.
Amazon com Weather Station with Wireless Outdoor Thermometer 31215 Home...
Jul 24, 2016 | Measuring Tools & Sensors
I have the equitytime thermometer model 31215B and it beeps frequently, all day long. Is there a way to turn the beeping off?
press alarm button until time and one bell shows, then press + button on back until all bells disappear.
Dec 31, 2012 | Audio Players & Recorders
Lost my instructions. I replaced the batteries and I can't get it to sinc up.
go to http://www.taylorusa.com/digital-indoor-outdoor-thermometer-1.html and select the link for the manual (Instruction Book under support info, bottom right)
Jan 29, 2011 | Taylor 1522 Indoor Outdoor Thermometer
I have a TX6470 and cannot receive the outside temp on the inside unit
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. If there are reset buttons, also try them.
Oct 16, 2010 | Timex TX6490 Wireless Thermometer with...
I changed batteriers and now I can't get a reading from the remote. I have hit the reset on both units. Maybe not in the righ order.
I believe they ask you to press the reset button on the main unit first, but that may not be your problem. Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. Also, make sure the units are close enough to transmit.
Sep 26, 2010 | Oregon Scientific RMR382ABLACK Wireless...
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
Sep 18, 2010 | Acu-Rite Acurite Wireless Weather...
Outside temp does not read new batterys in both inside & outside unit
Aug 21, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Kitchen Appliances - Others Logo
661 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
