Question about Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 100 tape will not eject. Pops out but does not open to eject tape.
  • 62 Answers
Stockk up inside..
bring it to repair shop!!
Posted on Apr 07, 2010
I have a Canon Elura 65 mini DV camcorder. When I
I had this problem and I only ejected a cassette. I tried new and old cassettes. Same result as you experienced.
What I did and I again don't condone striking electronics as a means to repair them but, at the advice of another post and having tried everything I could think of, I stuck the bottom of the camcorder with the palm of my hand several times and it worked. I don't know why it worked and it really shouldn't have but it did.
I think the real problem is a cleaning/lubrication and ultimately should see service by a local trusted shop. Try it I had nothing to lose and it worked for me.....
Dec 19, 2009 | Canon Elura 65 Mini DV Digital Camcorder
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
Cassette won't eject!
I have had this problem too. I got it to open by pressing my hand against the tape mechanism then slightly closing the lid and re-opening it. This doesn't always work the first time.Once it is open run a tape head cleaner and it should fix it for a while.
Sep 07, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 100 Power Dead
Just an update.
I sent it back to the factory - and they fixed the power unit.
However, they told me that now my Memory card and memory card operations will not work.
They did not charge me for it - they took it under warranty.
Everything else seems to be working.
Oct 23, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Remove The Casette Message
THESE CAMERAS ARE PEICES OF ****!!!!!!!!!!!!!!!!!!
I suggest that no body buys from cannon again!!
I am suppose to record my sister-in laws wedding and BOTH of my ELURA 100's are displaying the EJACT TAPE message!
"TEMP. FIX"
This takes pateince however for me it works....When you get the EJECT TAPE mesage....eject the battery with the power on (thus the power will go off by means of the battery not being in camera) then slap the battery back in....and KEEP doing this untill eventually the camera will NOT DISPLAY the message and actual work.
It may take up to 20 trys ....slap it in..slap it out...slap it in slap it out...BUt for me it works.
If it appears to work but as you hit the RECORD button it beeps and displays the EJECT tape message again...Go back and eject the battery again and repeat the STEPS...but dont worry , that means your getting closer to it working.. LOL
P.s- I hate CANON
Sep 23, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Elura 85
Take the camcorder to an authorised service center. They will have to open the camera up and have to manualy operate the mechanics to have an ejection of the tape. Most likely there is a failure in the camera that will have to be maintenenaced.
Jerry G.
Apr 10, 2007 | Canon Elura 85 DV Digital Camcorder
Tape problem, Elura 100
I called the factory and they said to send it in for evaluation.  While packing it up, I dropped it and lo and behold it started working.   Even though it started working, I decided to send it in to the factory and they found something "loose" inside and repaired it at no charge.
Feb 27, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Tape won't come out!
I had the exact same problem, and just by dumb luck, I managed to get the tape compartment to pop open after trying hundreds of things. Maybe this will work for you too...who knows??? What I did was to first remove the battery and AC power to "reset" the camera (I guess). I then put the battery back in place and WHILE HOLDING THE CAMERA IN THE UPRIGHT (AS IF USING THE CAMERA FOR VIDEO) POSITION, I pushed the "Open/Eject" latch. VIOLA!!! Like I said, it may be dumb luck, but I haven't had the problem again. It may be that gravity helped to take the stress off the ejecting mechanism...dunno???? BTW, when I was having the problem, the mechanism would "click" 3 or 4 times while trying to move the tape out. Good luck!!! I hope this helps someone!
Jul 24, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Canon Elura 100 Mini DV Digital Camcorder Logo
468 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
