Question about SanDisk Sansa Fuse MP3 Player
I can't hear music in my sansa
I have a sansa fuze 4GB, i try listen to my music its shows that is playing but i cant hear anything,and I also try playing my music through windows media player but it also cant play .all my music is still there whats wrong with it?
Posted by sgtaxel666 on
wwlvictoria
    Renaissance:
    An user who is expert in 3 categories / brands.
  • SanDisk Master
  • 1,001 Answers
Bluetooth Headphones V3.0 Handsfree Stereo Wireless Headset with Microphone earbuds for Apple and Samsung LG https://www.amazon.com/Charm-sonic-Bluetooth-Headphones-Microphone/dp/B01H6D7P7O/ref=sr_1_1?ie=UTF8&qid=1484100565&sr=8-1&keywords=Charm+sonic
Posted on Jan 11, 2017
treeeee
    Master:
  • 519 Answers
Bluetooth Headphones V4.1 Wireless Sports Stereo Earbuds with Mic, Noise Cancelling, IPX4 Sweatproof, 8 Hrs Playtime Amazon com YELLWWORSE Bluetooth Headphones V4 1 Wireless Sports Stereo...
Posted on Nov 25, 2016
Anonymous
    New Friend:
Plug the headphones in.
Posted on Apr 07, 2010
Why wont this sync with my itunes library?
Hi, Is the SanDisk Sansa Fuze compatible with iTunes? In some ways, it is. Unfortunately, the Sansa Fuze and iTunes don't always play nice together. You'll have to get a few workarounds to make these two sync together.
The SanDisk Sansa Fuze and iTunes
The SanDisk Sansa Fuze is natively a Windows product. You should be able to sync it with Windows Media Player automatically. However, not everyone owns a Windows PC and even if they do, they might store more music in their iTunes library.
If this is the case for you, you might find it helpful to be able to sync your Sansa Fuze with your iTunes music library. Bear in mind that you won't be able to sync apps, games or any other iTunes products that are not formatted for use on a Sansa Fuze.
Using iTunes with the Sansa Fuze
So, is the SanDisk Sansa Fuze compatible with iTunes? If you download the right software, it is. Apple offers a free download that works with many other non-iPod MP3 players, Sansa Fuze included.
Unfortunately, this product only runs on a Mac operating system. However, if you own a Mac, this is great news because it means you can still use your Fuze without buying a Windows PC.
If you use a Windows PC and want to transfer your iTunes music to the Fuze, don't lose hope - there's a way to do that, too.
Syncing the Sansa Fuze with iTunes
If you're using a Mac, visit this link for Apple's free software download. It comes directly from Apple, so you can be assured that it's spyware-free.
Install the software on your Mac. You need Mac OS X 10.4 or higher as well as iTunes version 8 or higher.
Plug your Sansa Fuze into the Mac and wait for the software to open. You should see a listing of your iTunes music library pop open in a window. You're then given the option to sync as many songs as possible onto your Fuze.
The syncing process is similar to syncing an iPod. Don't unplug the device until it's finished.
Syncing the iTunes Library in Windows
You can sync your Sansa Fuze with iTunes using a script called the Automator, found here. Once downloaded, open the script under your "Downloads" folder on your "C:" drive and find a string of characters that looks like this: "/Users/richard/Music/*.mp3".
Replace the name "Richard" with your own username. Don't change anything else. Select "File," "Save" from the menu.
Select the Automator icon with the right click button on your mouse and choose "Open with," "Automator Runner." If working properly, this should automatically sync the music from iTunes with your Sansa Fuze.
If that doesn't work, go into your iTunes library and highlight any DRM-protected tracks that you purchased from iTunes. Right-click and select "Make MP3 Version." These should now be compatible with the Automator.
This sounds like more or less of a "hack" than a solution, but this might be the only way to sync music from iTunes to your Fuze using Windows. If all else fails, make MP3 versions of the songs as shown above, then navigate to your iTunes folder where those files are stored. Then drag and drop these into Windows Media Player, where they should sync right onto your Fuze.
Hope that helps..
Feb 17, 2011 | SanDisk Sansa Fuze MP3 Player
I don't know how to download music on my sansa fuze (4GB)
On your Sansa Fuze, go to the "Settings" menu, then go to "System Settings", then go to "USB Mode", then select "MSC".
Now, connect it to your computer, then double-click "My Computer" on your computer's desktop to run Windows Explorer. You should see your Sansa Fuze show up as "SANSA FUZE". Double click on "SANSA FUZE", and you should see a folder called "MUSIC". Copy your music into that folder. When done, unplug your Fuze and your music will be on it.
Jan 27, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Fuze Music not showing up in the folders
check if you have a virus get firmware updates
Jan 23, 2010 | SanDisk Sansa Fuze MP3 Player
Sansa fuze 8mb format and firmware update
go into device manager in computer management and uninstall the sansa driver. Restart the computer and plug it in again
Jul 15, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa screen went white
Try resetting the device by holding teh power switch in the ON position for about 15 seconds, then while it's OFF, slide the power switch DOWN to the HOLD position. Now for the tricky part, let's force a manual MSC connection. Press and hold the center button while plugging in to the USB port. Let us know if the screen lights, and the battery begins charging in this mode. If it's charging, let her charge for a while to give the battery a chance. Then, open a Windows Explorer window. I like to use [Windows key] + E, or go to My Computer. See if the Fuze appears under "devices with removable storage". If it's communicating, you have the options of formatting the device and reloading the firmware.
Jun 06, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa Fuze wont work with home stereo
The Sansa doesn't play music through the USB port. You can connect the Sansa to your stereo via the Sansa's headphone jack.
Feb 22, 2009 | SanDisk Sansa e250 MP3 Player
My songs wont add on to my mp3
If your sansa 'fuze', right dosen't like your media get the sansa media converting software, My Fuze came with a mini-cd, if yours didn't you can download the official sansa media converter on
www.sansa.com/downloads
I hope it works for you! -Aptera P.S. I have no clue about MAC OS
Nov 27, 2008 | SanDisk Sansa Fuze MP3 Player
Cant load music
i had the same probleme with my sansa fuze. what i did was call the customer service, they walked me through my copmuter and helped me figure it all out.
you can look through you windows media player, my computer, and if after customer service you still havnt got you player working, might just be a bad one.
i had to exchange for another, and this one works.
help line 1-866-726-3475
Jul 02, 2008 | SanDisk Sansa Fuze MP3 Player
Open Questions:
SanDisk Sansa Fuse  MP3 Player Logo
443 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
