I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network
0. Install the yellow machine software on the PC
1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8.
2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears.
3.Click Edit.
4.Select Yes to Enable LAN Interface. Default: Yes (Enabled)
• If you select No, all other LAN option fields are blocked.
• If you disable the LAN Interface, the only access to the Yellow Machine appliance is
through the WAN port. Anthology Solutions does not recommend this configuration.
5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled)
6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address
• Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine
appliance connects to either a router that has DHCP service enabled or to a cable
modem. This setting makes the Yellow Machine appliance a DHCP client on your
network.
• Obtain IP Address from ADSL provider is greyed out.
• Choose Static IP Address if your network is locally defined and controlled and does not
use DHCP services. Type the IP address manually.
7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply.
8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
