GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
It is the magnetron circuit that has failed. It the part that generates the microwaves that heat the food. If it is making a loud buzzing sound when you try heating something, then the magnetron is shorted out. The replacement cost for the magnetron is almost as much as an new oven, so it does not make sense to have it fixed. Sorry.
If it stops heating and the other parts of the oven still work, the problem is with the magnetron circuit. If it makes a loud buzzing noise when you try to heat the food, then the magnetron has shorted out. The replacement cost for the magnetron is almost as much as a new oven, so it does not make sense to have it fixed. Sorry.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron, near the blower housing.)))
(((The fuse is located inside the unit along side the magnetron)))
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
