You will need a 3.5mm mini to mini cable (available at any good car audio store for between $10-20. Plug that into the headphone jack on your ipod and then into the aux input on your stereo. Then select aux-in as the source on your Kenwood. Now play the music on your ipod at about 3/4 volume on the iPod.
From what little research I did it does not look like you can connect and Ipod without extra gear. Here is a link to some of the accessories that you can hook up to it: http://www.crutchfield.com/p_113MP228/Kenwood-KDC-MP228.html?tp=5684&tab=other_items
If It was me, I would just spend the money on a stereo with a usb port. Then you can connect your Ipod directly to the cd player and operate your Ipod playlist with the cd player itself. Plug it in throw your Ipod in a cubby hole and use the cd player.
Make sure that when you hooked up your 4 channel amp to the remote turn on lead it is the same as the sub. Only hook amps to the Blue w/ white strip. The solid blue is power antenna lead and will lose power when on CD, ipod etc and only stays powered when the Tuner is on. Hope this fixes your problem.
it should be in aux try to press source buton and see if that is an option if not an alternative is to hook it up on the back of the cd player in the audio in or aux or aux 2 using a wire adapter from walmart in the car sterio section
They dont work with classic ipod for direct ipod connection, also try updateing the firmware in your ipod this is a common problem, deck looks sweet tho eh?
The 890 doesn't support iPod control via USB. You can only read plain data storage devices on the USB port, such as a flash drive or portable hard drive. When you plug the iPod in (to a PC or the 890), it doesn't show up as a plain file storage device. Some of the newer Kenwoods do offer direct iPod control via USB. These ones have more "smarts" and are able to properly talk to the iPod and access its music. For the older models, you'll need to buy the special iPod interface, which accesses the iPod like a CD changer.
How bout the 205?
