CE is a communication error.
This is an automatic check performed anytime the unit is powered up. If there is no data communication between the main panel and the ignitor you will get this code within 30 seconds.
If communication is re-established this code will disappear.
DO NOT do any of the following with AC power on / to the unit.
First check the ignitor then, the wiring and terminals from the ignitor to the main board.
There just might be a corrosion problem with the circuitry or corrosion on the main board itself.
Thanks for using FixYa.
Kelly
