SOURCE: Quickbooks Pro-restoring a back up from a previous version 2005
If is any help - we have just had the same problem.......had version 5 (very old) of QB
changed computer to Vista and would not work so had to buy Pro 208 for Vista . We really had to get in touch with Quickbooks - they send you a free upgrade kit (disc which is Pro 2006 version (not a fuull version but enogh to get the data over) then you load that on your old machine transfer your data to that then copy that again - then load into Pro 2008 - worked fine for us - have come across a hiccup with VAT - but however I guess we are going to have to give in and phone them after the Bank holiday........apart from that everything was fine.
be brave and phone 'em - tech support was helpful.
SOURCE: quickbooks pro 2005 I cant open my backup files
You are not able to open a backup file in Quickbooks, Only restore it, to open a previous backup, the easiest way is to make a copy of your current company file, then restore the backup over it. This will give you a company file with the backup data.
SOURCE: i cannot save a backup copy of my quickbooks 2007
rknrobbyy,
Try this: with the QB file open go to FILE..... UTILITIES....VERIFY DATA (this will go thru a process to identify if there is a problem) If there is a problem QB will let you know then the next step would be to rebuild data.
IF this does not work there are a few other things you can do. You can call me @ 612 718-3023 and I can walk you thru the process. ThanksTammie Nasseff CPA
