When scanning a document and saving as PDF, the output size is way too large. How do I adjust my output size?
It depends also on what you are scanning....half tones, pictures etc. but the easiest way to control the file size of PDF's is to change the resolution setting. Also referred to as the quality setting. These are settings like Super Fine, Fine, Standard. It should be right on your control panel. It is the same setting you can change when sending a fax. If your default setting is Fine for example, changing it to standard will use a lower resolution and reduce the file size. In other words the higher resolution/quality setting you use make the file size much larger.
Good Luck and Thank You for using Fixya.
