Headlamp Adjustment —Screen Method Aiming
NOTE: Horizontal aim is not necessary for this vehicle and is not adjustable.
NOTE: Consult your state's vehicle inspection manual for recommended tolerance ranges for visual aiming.
Before starting headlamp assembly adjustment:
NOTE: The center of the lamp is marked by a 3 mm (0.12 in) circle on the headlamp lens.
Mark a horizontal reference line on the vertical wall or screen.
Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
On the wall or screen, locate the high I just installed the right head light on a 2000 - 7ced4e6.gifrea of the beam pattern.
NOTE: The appearance of the beam pattern may vary between vehicles.
Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff I just installed the right head light on a 2000 - 1fb716f.gif with the horizontal reference line, the headlamp beam will need to be adjusted.
