I have a TH58PZ750 and a stripe about 3" across and the same distance from the left side going down half way (maybe about 1/10 of the top half of the screen) does not show the proper colour, seems to be missing reds , just started about 1 and a half weeks ago, bought it through the internet from the US and bought extended warrenty, but company out of business
Red=ignition
Yellow=memory or constant power
Orange=illumination
Black=ground
Blue/blue w/white=Amp remote
Speakers are white/white w/stripe= front left
grey/grey w/stripe =front right
purple/purple w/stripe rear left
Green/green w/stripe rear right
If its a dvd player one wire will be for brake "ground" (have to be in park in order to watch movie unless bypassed)
Hi, Here is the wring harness colour code for Pioneer.
Yellow= Constant 12V Red= Switched 12V Black=Ground Blue=Power Antenna Blue/White stripe= Power Amp Rmote turn-on White & White/Black stripe= Front Right Speakers Grey & Grey/Black stripe= Front Left Speakers Purple & Purple/Black stripe= Rear Right Speakers Green & Green/Black stripe= Rear Left Speakers Orange= Illumination
your right front speaker neg side is Green with a orange stripe
your right front pos side is Light tan with a green stripe
your left front neg side is a light blue with a white stripe
and the left front pos is orange with a green stripe,,
a typical new radio will have a gray with a black stripe for the neg side and solid gray for the positive, on the right side
and the left will have a white with a black stripe for the neg, and solid white for the positive, if you need anything else just reply to this feed and I'll help you
The transfer roller may have a flat spot on it. (I assume the stripe runs parallel to the narrow edges of the paper.)
A roller problem will show up as a repeated stripe. Measuring the distance from one stripe to the next (use the same edge on each stripe) will give you the circumference of the offending roller. Divide this by ? (about 3.1416) to get the diameter. Each roller is a different diameter, so that makes it easy. Use the metric edge of the ruler - the math is simpler.
yellow - constant power, red - switched or ignition power black - ground white - left front speaker pos. white/black stripe - left front speaker neg gray - right front spkr pos gray/black stripe right front spkr neg green - left rear spkr pos green/black stripe - left rear spkr neg purple - right rear spkr pos purple/black stripe - right rear spkr neg blue - power antenna remote blue/white stripe - amplifer remote turn on
Side 1 Side 2 White Orange White Orange Orange Orange White green White Green Blue Blue White Blue White Blue Green Green White Brown White Brown Brown Brown
Cross Cabling :
Side 1 Side 2 White Orange White Green Orange Green White Green White Orange Blue Blue White Blue White Blue Green Orange White Brown White Brown Brown Brown
Hope this helps. Please rate my response. Thanks. Have a good day.
This is the typical configuration for the wires coming from a car stereo.
Right Rear Spkr (-) = Purple w/ Black Stripe
Left Rear Spkr (-) = Green w/ Black Stripe
Right Front Spkr (+) = Purple Gray
Left Front Spkr (+) = Dark Green White
Right Rear Spkr (+) = Blue w/ Orange Stripe Purple
Left Rear Spkr (+) = Brown w/ Blue Stripe Green
Power Antenna/Amp = Blue
+12 Volt Battery Wire = Yellow
+12 Volt Ignition Wire = Red
Right Front Spkr (-) = Gray w/ Black Stripe
Left Front Spkr (-) = White w/ Black Stripe
A Right Rear Spkr (-) Dark Brown w/ Pink Stripe Purple w/ Black Stripe
B Right Rear Spkr (+) Tan w/ Green Stripe Purple
C Right Front Spkr (-) Green w/ Orange Stripe Gray w/ Black Stripe
D Right Front Spkr (+) White / Green Stripe Gray
E Left Rear Spkr (-) Tan w/ Yellow Stripe Green w/ Black Stripe
F Left Rear Spkr (+) Tan w/ White Stripe Green
G Left Front Spkr (-) Lite Blue w/ White Stripe White w/ Black Stripe
H Left Front Spkr (+) Orange w/ Green Stripe White
I Amplifier Turn On Do Not Use For This Vehicle
J Power Antenna Turn On Do Not Use For This Vehicle
K Ground Wire Black w/ Green Stripe Black
L Do Not Use For This Vehicle
M Dash Light Dimmer Wire Orange (if available)
N +12 Volt Ignition Wire Thin Black Wire Red
O Do Not Use For This Vehicle
P +12 Volt Battery Wire Green w/ Black Stripe Yellow
Appreciate the update and additional information. If I understand it right, your vehicle then has two connectors at the back: 1 big black/red/gray plug:
Yellow/light Green - always ON B+12;
Yellow/Black stripe - ACC B+12 goes to the IGN switch;
Black - chassis/ground;
Blue - remote trigger for add-on amplifier (if connected);
Blue/Red stripe - illumination (can go to parklight switch).
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe Car Radio Ground Wire = Black Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe Car Radio Dimmer Wire = Light Blue w/ Red Stripe Car Radio Illumination Wire = Orange w/ Black Stripe ?? Don't know ?? Red Wire (No power to wire Constant or Accessory) Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front: White w/ Green Stripe (+) Brown (no stripe) (-)
Right Rear: Purple w/ White Stripe (+) Light Blue (no stripe) (-)
Left Front: Light Green (no stripe) (+) White w/ Orange Stripe (-)
Left Rear: Light Blue w/ Black Stripe (+) Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front: White w/ Green Stripe (+) Green w/ Orange Stripe (-)
Right Rear: Orange w/ Red Stripe (+) Black w/ White Stripe (-)
Left Front: Orange w/ Green Stripe (+) Blue w/ White Stripe (-)
Left Rear: Red w/ Green Stripe (+) Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
