Question about Grundig S350 AM/FM/SW Radio
Simple wire can make a great antenna, and it's relatively inexpensive. I've had the best shortwave and AM reception thus far using a long loop (actually a rectangle) of copper wire as an antenna (but folks shouldn't try a loop with some radios designed for use with powered antennas without inserting an appropriate capacitor in series). If you do try wire, you would want to try to make the loop shape as large as possible, and connect the ends of the wire to your radio's antenna connectors.
Posted on Apr 08, 2010
You can also take any metal slinky and solder a single alligator clip to each end of the spring coil after removing the small metal clasp at the end of the coil of wire. This gives you a collapsible wire antenna that you can clip to a drape, or any hanging item using the clamp. And the other end can easily clamp to your telescopic antenna with out scaring or damage.
It works horizontally or vertically as an antenna. And you can add an additional slinky rig to make it even longer.
You can suspend it by hanging it off a balcony, clipped to a tree limb, a table umbrella, or with a fishing pole inside as a vertical antenna support.
Or along a simple string or cord as a horizontal antenna support.The original slinky box still makes a handy carrying case for your travel antenna to fit into as you travel.
Posted on Nov 23, 2014
Dec 11, 2014 | Grundig Eton Satellite 750...
Sep 22, 2013 | Grundig S350 AM/FM/SW Radio
Apr 01, 2011 | Grundig S350 AM/FM/SW Radio
Mar 03, 2011 | Grundig G6 Aviator (Buzz Aldrin Edition)...
Oct 14, 2010 | Grundig G5 AM/FM/SW Radio
Nov 08, 2009 | Grundig S350 AM/FM/SW Radio
Aug 10, 2009 | Grundig YB 400PE AM/FM/SW Radio
Jan 24, 2008 | Grundig YB 400PE AM/FM/SW Radio
Jan 08, 2008 | Sony XPLOD CDX-GT200 CD Player
826 people viewed this question
