Question about NetGear MA101 802.11b Wireless Adapter
Netgear MA101 802.11b wireless needs secure code for router
How do I give the MA101 the secure code for my linksys router. The MA101 recognizes the connection but is unable to connect because I don't know how to tell t my security key.
  • 550 Answers
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Posted on Apr 07, 2010
  • robert w
    robert w Apr 07, 2010
    Click Here for step by step
    instructions
  • robert w
    robert w May 01, 2010
    Click Here to try step by step solutions.
    Most of the users are using this web site for home network troubleshooting
Wireless security
I think you should upgrade the firmware on your router.
After upgrading the firmware reset the router and reconfigure it manually.
I will also suggest you to create a new wireless network and use security modem WPA.
Try to connect to the new wireless network and see if that works.
See linksys router setup
Watch : How to reset Linksys router.
Jan 25, 2012 | Linksys Wireless-G Broadband Router
Want to connect to internet through a wireless computer and when I try the site wants a security code and I don't know the code or where to find it
Is it asking you for wireless network key?
You need to check the wireless settings of your router.
Connect one computer to the router with the Ethernet cable.
OPen the setup page of the router and check the wireless settings of your router.
Dec 12, 2011 | Cisco Linksys RangePlus Wireless Router...
How can I be sure my linksys security is up to date without the original disc that came with the router? I am trying to be sure that my linksys is not an open gateway for neighbors to steal access from...
If you want to make sure that the signal from your router is secured, the only way you need to do about that is to put in a password or passphrase before connecting to the wireless connection. that is the security the router can give you. unless they know the code. they wont be able to connect to your router freely. and about the updates on the linksys, it is ok not to update at this point. and even if you dont have your disc. the router will still work. the disc only give you a software for the router to connect automatically. while windows can already give you that option.
Hope this helps. thank you for using Fixya,
Jun 11, 2011 | Linksys Wireless-G WRT54G Router
Kindle 3rd Generation -- Linksys WRT54G router. Kindle won't recognize password set in router -- Always says "Unable to connect to Wi-Fi Network. Would you like to enter the passworsd again or...
I don't have a solution -- I'm having the exact same problem and I'm looking for a solution. Called Kindle tech support, and all they could recommend was to go to McDonald's to see if I can connect using their wireless. They DID say this Linksys WRT54G router is a compatible router with the 3rd Gen Kindle.
Jan 12, 2011 | Linksys Wireless-G WRT54G Router
Lost password for linksys 2.4 router
Step 1 : Connect - Router - Computer ( Wired )
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer
Step 3 : Default password is admin
Step 4 : Click wireless
Step 5 : Choose wireless security
Step 6 : Here you can find the Password
Step 7 : Try to connect with this password
let me know if this works
Regards
TOM
Dec 30, 2010 | Linksys Wireless-G Broadband Router
I cannot connect my Apple iPhone with my Linksys router. Please help.
hi
have WPA2 security enabled. When I type my password the iphone says "unable to connect." I just disabled the security on my router and was able to connect. How can I connect my iphone with the security enabled???
Nov 11, 2010 | Linksys WRT160N Wireless Router
Kindle 3rd Generation -- Linksys WRT54G2 router. Kindle won't recognize password set in router -- Always says "Unable to connect to Wi-Fi Network. Would you like to enter the passworsd again or manually...
First Check if u are Entering correct Password
Plz also Check security TYPE u have Chosen for Wireless
Might not work with Advanced Security
Try WEP or WEP
All the Best.........
Oct 07, 2010 | Linksys Wireless-G WRT54G Router
I purchased a new laptop,,and when Itried to connect to the internet wirelessly it recognized my router, but asked for security code. I don,t know what my code is.
if you don't know your security code, then you will need to reset the router (Use the reset button on the back) then you should be able to connect wireless unsecured. from that point you can type the default gateway IP address (192.168.1.1) in the address line of internet explorer, this will open the web interface of the router (Leave username blank, admin for password) then you can re-enable wireless security and pick a new code (I recommend an old 10 digit phone number you can easily remember but hard for others to guess)
Sep 25, 2010 | Linksys Wireless-G WRT54G Router
3 failed attempts to connect HP DV6t laptop
First as a test, turn off the wireless security, and see if the laptop can connect.
If it can connect with security turned off, then it is likely that you are making some type of mistake with the password. (Such as caps lock being on, or having a keyboard error.)
Good Luck!
Jan 03, 2010 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Hawking Extender- Connected to WiFi but cannot access Internet
First think I always do is Reset Linksys Router and disconnect extender. Then turn off all security on router. Do soft reset on ipod. leave extender off and see if you can connect to the linksys. If you can then plug in extender (still with security off) then see if ipod connects to extender.
you might have to soft reset ipod again once you connect the extender.
if that works. reset security. Let me know how that goes.
Jan 01, 2010 | Hawking 802.11g Wireless-G Range Extender
NetGear MA101 802.11b Wireless Adapter Logo
139 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
