Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
Hardrive light flashing iomagic 250gb
Hardrive light flashing and I dont see the drive on my computer
Posted by jac_leroux on
Amir Zahirovic
    New Friend:
  • 38 Answers
Try disconnect your hard drive and then connect it again,start your cpu,if that don't work i thing your hdd is near end.....
Posted on Apr 06, 2010
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
My toshiba 593500-a external harddrive isnt detected
hi i dont know how old this post is??
but right now iam having the exact same problem the only curious thing is that it works on MAC but not on PC, any help please?? or did you find a solution ???
thanks a lot
Jan 14, 2012 | Computers & Internet
The hardrive lights up but stops there with no flashing lights and no showing up on my mac computer.
Try in another PC? If it is still the same you may have a problem with the USB cable or your power unit in the hard drive is faulty and may need repair/replacement.
Hope this helps
Thanks
Jason
Jul 20, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Whenever I plug the lacie hardrive into my computer nothing happens on the computer but a red light turns on and flashes on the lacie
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 26, 2010 | LaCie 301103U 500 GB USB 2.0 Hard Drive
When hardrive connected it says found new hardware
You need to format the external drive. Format the drive as primary drive ans in FAT32.
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that its Healthy.
Oct 02, 2009 | Acer Computers & Internet
I have a Maxtor 80GB external hardrive and I can't get into it. I have checked all the plug connections, shut the computer off and rebooted. The short cut to my photos on my desktop has also disapeared and...
Flashing light shows that your pc is comunicating with the drive, so it is posible that it is damaged, is the disc ide or sata, try conecitg it directley on the motherboard like a slave disc.
Sep 01, 2009 | Maxtor Computers & Internet
Verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Jun 09, 2009 | Verbatim 160GB USB FireLite: The "drive...
I dont understand how to hook up my old hardrive to the sabrent hardrive enclosure
Open the enclosure, plug the IDE cable into the back of the hard drive. Plug the power connector into the back of the hard drive. Mount the hard drive with the included fasteners. Close the enclosure, Plug in the power supply to the wall. Turn on the external drive. Plug in the USB cable to your computer. Browse your files.
Apr 26, 2009 | Computers & Internet
Hardrive not recognised my computer yet the power light is on
go to control panel.. go to Administrative tools.. then .. go to computer management.. on the left pane.. click disk management.. u can detect all ur drives in here including those who are not seen by your MY COMPUTER..
Apr 13, 2008 | Computers & Internet
Power Problem
Check if you plugged in your monitor cables just right, check it, plug it in, I dont know any other cause of this.
Mar 17, 2007 | E-Machines T1742 PC Desktop
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
327 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
