Hi, can anyone sove my problem. Water pours out of the soapowder drawer when my machine is rinsing. Can this be repaired or do I need to buy a new machine. Thanks.
Remove the dispenser draw and pour water down the soap chute as much as you can to soften any soap causing the blockage. When the water level drops, add more water. After a while use a soft flexible rubber hose and run it down the chute up and down to remove caked soap. Once this has been achieved, run the machine on "Rinse & Spin" to clean out the drum.
The lower left panel is a filter that should be cleaned out regularly - the filter
is also connected to the drain pump which rids the washer of the water.
When you clean the filter out - make sure you have a bowl or Tupperware
handy that holds about 2 quarts - slowly remove the filter and the
water will drain into the bowl. Clean out any debris and reassemble. If
the filter is not seating properly in its seat - water will leak from
the small hose - the filter is what blocks the water from coming out of
the hose.
Hello Everyone,
I had the same problem with my washing machine, what I didn't find the push button they are talking about, but what I realised, that at the bottom of the drawer, in the middle of it, there is a hing that keeps the drawer in its place, I used a screw driver to push that hing, and got the drawer out.
I have cleaned the fabric softner section, but when i put it on again, I got the same problem again, I am not sure about the reason of that.
If someone can help on that one, that would be great ;)
I have th same problem, apparently a possible cause could be a partially blocked pump filter. Just trying to get infoon where this is and how to get to it though.
Angie, pull the drawer all the way out and see if you have a lid seal blocking the inlet tube. There should be a releasing tab in the back. Just take your finger and feel where the fill port is. I have found many bottle lid seals blocking this fill port. Catriver..post back.
