Question about HP PSC 1610 All-In-One InkJet Printer
Error messages and printing problems
My printer won't print out my documents and now every time i want to make a copy an error message pops out. the error message is "paper size error". the paper size i use is 8.5"x11'. how can i fix these problems? thank you.
Posted by jessii_1993 on
Sandeep Gupta
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 137 Answers
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Regards,
polysandy
Posted on Apr 06, 2010
HP PhotoSmart computer indicates "open door"
Open "Devices and Printers" in start menu.
Right click printer with green arrow - click see whats printing.
Delete all documents.
Restart computer - then restart printer
See if that clears your error messages.
Mar 12, 2014 | HP PhotoSmart C4345 AllInOne InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
My hp deskjet printer can not copy or scan
Error message?
Just put something on the scanner glass and press the print button in the printer itself, leave the computer alone.
Did it work? if so... there's something wrong with the HP software, re-install.
That machine takes copies without the computer on, so, it should work.
Sep 12, 2009 | HP DeskJet F380 All-In-One Printer
Lexmark printer prints only one page of multi-copy document
Any error messages on the printer? Any error messages through the operating system? (Normally, you'll see a printer icon in your task bar or the Mac whatchajiggit bar.)
Try an updated driver, as well. Go to
http://www.lexmark.com
Drivers and downloads
Driver finder
Start typing in part of your printer name
Click on the name that pops up
Pick your operating system
Download the driver
Install
Dec 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
Hp D4260
I too have problem when printing multiple copies. Word just crashes out.
Any ideas how to fix???
May 02, 2008 | Office Equipment & Supplies
HP PSC 1610 All-In-One InkJet Printer Logo
471 people viewed this question
Ekse
Thomas F. Schneider
