Question about Technics DJ Headphones
My earphones just suddenly stopped producing sound. No signs of blow-out: No static or crackle sounds..just, one night they stopped working. I don't want to throw them away as they've served me well for years. What caused this, or how can I fix them? -Gjestar
Posted by djgjestar on
Grubhead
  • Technics Master
  • 5,700 Answers
See if my tip on headphones will help you with this problem.
Posted on Apr 14, 2010
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
I get static and crackling sound out of right speaker, then it blows the speaker fuse, Sanaui au-999 what is wrong
Any of the transistors in the right channel power amp section circuit will have the fault. Check it. A very skilled work indeed.
Apr 15, 2012 | Audio Players & Recorders
Im having a problem that alot of other people are having. my 112 is giving off this constant static and crackle. ive been reading that it could be abad jack in the effects loop.if anyone knows exactly what...
Could be a bad jack like you say. Have you changed your guitar cable? Your cable can make a HUGE difference. Can't know exactly which part it is unless its sitting here in front of me...
Sep 03, 2011 | Peavey Valveking 112 - Tube Guitar...
Last night, 4-24-20ll (in the middle of the night) I was watching a video and suddenly there was a crackling noise like static. Then the sound disappeared completely and never came back.
I think a harsh sound damaged the speaker. This is usually caused by software signed to enhance audio performance, such as VLC (which has high sound volume), Breakaway (a so sound-enhancing software, etc. First of all, try uninstalling such programs, or if you have not installed such programs, try restarting your computer several times. Secondly, test other speakers (external) with your computer to see if the problem is from your previous speakers. Hope this helped.
Apr 25, 2011 | Computers & Internet
My ipod crackles and my hearing seems to be getting damaged
Id say you should go see a doctor. But for now id say that you should do your best to not listen to it for a while as it can affect hearing. try to use full on speakers if you can. On you tube there are a few Sub-Woofer sound tests you can do. Try playing one (low volume) and repeat. (not a song one)
http://www.teenbuzz.org/ also to hear which frequencies are out of range to you click here. ( click the second icon on the list further down the page)
But yeah go see a doctor. Perhaps some ear drops.
Sep 01, 2009 | Apple iPod touch
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
No clean air smell/crackling & static
To stop the crackling sound, you need to remove all of the dust particles from the wire in the back. Sometimes when the unit is extremely dirty you can see sparks emanating from the wire, this is what causes the crackling sound. The unit has a built in cleaner you can lift up and down to perform this task, located on the top, but this doesn't work extremely well.
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Not sure about the smell though. Mine has started to smell a little strange and I haven't figured out how to fix that problem.
Oct 01, 2008 | Ionic Pro TURBO Air Purifier
Crackling Sound
Hello there
The issue that you are descibing sound it a bad small signal board which needs to be taken to thr repair shop.
Jun 05, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Technics DJ Headphones Logo
197 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
