Question about Brother IntelliFax-2820 Laser Fax
Jammed paper Don't know where to start. How do u get the paper out? What do I open to get the jammed paper out? Fax model 2820 oct 2007 ser. No. U61325K7N235451
Posted by pink3dev on
Anonymous
    President:
  • 405 Answers
There are 3 places to check for jammed paper.
Turn off the fax machine, then remove the tray and open the back cover, and open the front cover to remove the drum and toner (cartridge) and look inside machine.
After you find the jammed paper put the cartridge and tray back in machine and close all the covers.
Error message should go away.
Posted on Apr 07, 2010
"Back Cover is Open" error,
just remove the paper that jammed at the back side
May 08, 2011 | Brother IntelliFax-2820 Laser Fax
Fax machine 2820 not working at all - just beeps no matter what button is pushed
check paper ....!! or ribbon toner is it inserted properly
hope if it helps
Apr 04, 2011 | Brother IntelliFax-2820 Laser Fax
Brother fax machine says back cover open and it is not open. Why?
This message comes up sometimes when paper is jammed inside. Remove paper thru back cover.
Mar 05, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2820 JAMMED
just clean paper path and clean all roolers and specially paper pick up roller.by mian jee
Dec 15, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax machine Fax-2820 MFC-7225N
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
May 08, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Nov 21, 2007 | Brother IntelliFax-2820 Laser Fax
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
314 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
