Tokina ATX 116 PRO DX for Nikon Logo
Question about Tokina ATX 116 PRO DX for Nikon
Is there a manual for the ATX 116 PRO DX lens. I
Is there a manual for the ATX 116 PRO DX lens. I didn't have one for my lens when I bought it. Can I down load this manual?
Posted by don1374 on
Anonymous
  • 31 Answers
Tokens focus ring jam
Unfortunately, I think this'll mean a trip to the repair shop - I certainly wouldn't advise a DIY attempt (speaking from bitter experience !)
Canon T3i won't focus with a
As this if a manual lens only (Nil A/F) if its not working with manual focus there is a defect in the lens it will have to go to the manufactures workshop.
Pictures BLACK
Of course the D800 is full frame and the DX 18-135 is a DX. The only thing the D800 needs to do is switch to DX mode. The Nikon FF camera's can work with DX lenses. (if the lens has a chip) You still have a nice 15 Mp picture on the D800. But if something was wrong with the lens, you should have an error on the display.
Please to check the lens, switch to live view. You should see something. If not, really something can be wrong.
Carful go to taking a picture step by step. Be sure the lens is correctly put on the body. But before you put it on, look is all contacts are clean shiny and there are no dents.
Attempting to register new lens. unable to locate online
If you bought it in the US, start with
http://support.nikonusa.com/app/product_registration
If you bought it elsewhere, go to http://nikon.com/
Choose your location and go from there.
3helpful
I have the tokina atx 280 pro lens but no hood, where can i get a replacement hood? or other brands that can fit in my lens. thanks
Most good camera shops and even some online camera stores should be able to help you
Part# BH775
also look here and contact this site as as long as it fits the lens size you have a variety of shapes.
http://www.jsteven.net/tokina-lens-hood/
you can make your own see this page
http://www.lenshoods.net/hoods/Digital-Lenshood-Tokina-AT-X-280-Pro-AF-28-80mm-f-2.8.php
Please rate my help++++Thanks for using FIXYA
I just bought the Tokina SD 12-24 F4 (IF) DX wide-angle lens for my D70, and it does not autofocus. I'm being told by the company I bought it from that i am past their 2 week return policy. Does this lens...
Only the MkII version of this lens has an autofocus motor built in, the MkI relies on a motor in the body of some Nikon AF SLRs to autofocus. The D70 does not have an inbuilt AF drive motor, so if you have the MkI lens then you can only use it in manual focus mode on your camera.
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
1helpful
Does Tokina-12-24mmF/4Pro DX complies with Nikon-D3 FX Format
Barrel distortion like you describe can always be a problem, especially at ultra-wide focal lengths like yours at 12mm. Some of this can be compensated for in software... Adobe Photoshop CS2 and Elements do a reasonable job, IMO, Bibble Pro (www.bibblelabs.com) does even better, especially with the 3rd party plugins like Percy perspective correction. These are things we have to live with when we have smaller sensors and ultra-wide angle lenses. There is nothing wrong with your lens, you will probably find that this distortion is minimized if you use a longer focal length (say 14mm) and/or stop down the lens a bit.. try f8, wide angle lenses have huge depth of field.
3helpful
4answers
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Top Tokina Cameras Experts
Steve
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Tokina Camera Expert? Answer questions, earn points and help others
