Question about Toshiba TP55F80/81 55" Rear Projection Television
Where can i find a toshiba manual for a projection tv (tp55f80)? We are trying to locate how to enter the convergence service mode.
Posted by mamamia2102 on
shaun taylor
  • Toshiba Master
  • 1,527 Answers
Hello here is my email adddress [email protected] i'll send the manual for free only if you leave me a rating thanks
regards
shaun
Posted on Apr 06, 2010
Red light keeps flashing on toshiba theatre. How can I fix it?
on the older sets it is a short and usually in the convergence circuit, the way to know is located the convergence chips and unsolder both from the board (18 pins each) and if set then comes on (WILL LOOK BAD) one of the two chips is bad and both need to be replaced----should be stk-392=110 chips.
May 22, 2012 | Toshiba TP55F80/81 55" Rear Projection...
How to fix the convergence on a toshiba TP55D81 tv using the remote control
The convergence is adjusted with the remote by entering a tech menu and adjusting there====if convergence is really bad adjustments are not going to fix it.
The set should have in customer menu a limited convergence adjustment with up to nine points where you can adjust---if it will not adjust there in some way----convergence circuit needs repair.
Mar 16, 2012 | Toshiba TP55F80/81 55" Rear Projection...
Purple/Green Outline surrounding picture
I have seen two different things cause this. The first and most common is the electrical failure of one or both convergence IC's. A handful of times, the data in the DCU became corrupted and I was able to enter the service mode, go to manual convergence and correct the one location that was off.
Apr 28, 2009 | Toshiba 50HDX82 50" Rear Projection...
WHERE CAN I FIND AN ORIGINAL REMOTE FOR MY TP55F80?
The problem is probably that one or both of the STK convergence chips have failed. These control the convergence coils around the red blue and green guns and are the most common cause of sudden convergence problems and the protection circuit shutting the TV down when turned on.
I can post details of how I replaced these on my Toshiba 40WH08B. Yours should be similar.
Mar 02, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Tp55f80 tv. to much red on screen
You have a convergence failure. It may be possible to simply re-solder the pin connections under the convergence output ICs as they have a tendency to develop cold solder joints which cause intermittent mis-convergence. If the solder connections are good, then replacment of the ICs will be necessary. Expect to pay $350-450 to have a toshiba servicer fix this.
michtech
Feb 17, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Gun problem
Bill, the picture tells the story, you`ve lost convergence, either the convergence IC`s have failed or theres a slight chance that one of the convergence plugs got partially pulled out when you moved the set, of course the latter would be the easy fix, remove the back of the set and check all the plugs by pushing down on them or of course if you see one laying out of the plug just plug it back in. If the IC`s have failed or possibly the solder is broken on the IC`(s) and you are proficient with a soldering iron you can try re-soldering the pins, be prepared to lay on the floor for awhile there are 18 pins on each IC. check the plugs first (unplug the AC cord first), let me know if you know how to solder & unsolder and we`ll go from there, not much room on here to type in everything in one reply. BMW Rider
Dec 02, 2007 | Toshiba TP55F80/81 55" Rear Projection...
TP55f80
the lenticlualr screen part number is 23837437. the part is no longer available.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Aug 06, 2007 | Toshiba TP55F80/81 55" Rear Projection...
Toshiba TP55F80 convergence problem?
check the convergence chips for bad solders or even the crt sockets, I would lean more on the ic's and surrounding area.
Apr 18, 2007 | Toshiba TP55F80/81 55" Rear Projection...
TP55F80/81 55 in
no mater what I say you will need a tech, is note that you dont have experiece with this tv, so let the job to a tech, is better for you...good luck
Aug 09, 2006 | Toshiba TP55F80/81 55" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
