Fuji Fine pix S7000 looses settings when batteries are bieng char
When I remove the batteries to recharge them I loose all my settings. Is there a battery in the camera. If so, how do you replace it? Jack E [email protected]
There is no internal battery. When the batteries become discharged or removed, the camera retains the date/time settings for about 24 hours. Most people have backup batteries fully charged so when one set is low in the camera, they can make the change quickly.
remove the xdcard and use compact flash. also put camera in set mode and run the battery drain function. it seems to reset the battery voltage meter. clean batery contacts with q-tip and rubbing alcohol. worked for me
Hi. If your camera is turning on with the lens stuck out. Turn the camera on, and without turning it off, open the battery door, and take the batteries out. Leave it for about 1-2 minutes and try again. This process is call power reset. Usually works. Good Luck.
a well known problem , this camera eats batteries there are high power (2950MaH) accus , those should be used with this camera even with 2700 MaH it is empty real quick
If you are using rechargeable Ni-MH batteries discharge fully using the camera facility. Recharge and then discharge again. Recharge and hopefully the problem will be resolved.
