SOURCE: Whirlpool washer does not Spin fast
Is the drain hose blocked?
I had a wp washer and after moving into a new house we had a similar problem. I would come home from work drag the washer away from the wall, take it all apart and it would spin properly.
I'd button it all up and put it back in place and the next week she would complain again. When I was out of town she called the repair man. He came and cut 4" off the drain hose and the machine ran for another 10 years until the trany packed it in.
I guess the back pressure on the pump was restricting the transmission from spinning up to speed.
SOURCE: washer doesn,t spin
Looks like chat support session must have timed out. The answer to your last question was, yes, pres. analog switch with a red, a white, and a blue wire to it.
SOURCE: model 110 washer will not go into a final high speed spin.
is it top load or front loader kenmore what
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
