Question about Nextar X3-08 Car GPS Receiver
My nextar x3-08 keeps doing a faded looping screen scan. I've tried reseting it but it that doesn't work. The initial screen comes on then fades out and does an etch-a-scetch type loop.
Posted by gateway20672 on
Anonymous
    New Friend:
  • 5 Answers
The only way to get around this loop is to reboot the system with the reset button on top of back of unit and then return to your destination. The operating system has a glitch in it, no the unit
Posted on May 26, 2010
Anonymous
I am having the same problem. Did you ever get it resolved?
Posted on Apr 21, 2010
  • Anonymous May 26, 2010
    dean5643 -
    Thank you for the response. I have tried that several times, but is still not resolving the issue. I had since called Nextar tech support, and they too confirmed it is the operating system failure, and had no other solution for other than to buy a new unit, which I think is unacceptable, as they should stand behind the quality (or lack thereof) of their products. My next plan is to go to Kohl's and see if they will refund my money. Let me know if you have any other suggestions.
    Regards,
    Sfeudy20
Laptop screen fades in out
I also experience the same thing with my Asus netbook. It seems a common issue or a bug. I fixed mine by resetting the connection between the LCD and the motherboard. If you don't know how to open your computer, then I suggest that you get it serviced.
David
May 19, 2013 | ASUS Computers & Internet
Sheets how to wash do not fade?
I believe it's Tide, I could be wrong, but one of the major brands has
a detergent that helps to keep colors from fading. Also, don't wash them in hot water. The new detergents work just as well in cold
water as they do in hot. If you can line dry them, during the day when they can get a breeze, without being in the sun, that might
help keep your colors from bleaching out. If the sheets are from
your sons bed, you might think about getting some of those pads
like the hospital uses. You know the blue ones that they always
put under you on the bed. They make some that are pretty big.
I would check at a Walgreens or CVS. They should carry them.
Jul 30, 2012 | Kidsline Mariposa 3-Piece Crib Bedding Set...
I´ve a pda hp h5455 that don´t start , i´ve tried to do a hard reset and charge it via USB and nothing hapens
To do the hard reset, while on battery (NOT A/C) power, hold down the two outside front-panel buttons (Calendar and iTask), While holding them, press the reset button with the stylus. Keep these buttons all pressed until the image on the screen begins to fade (about 4 seconds), then you can release the reset and application buttons. To restart your iPAQ, you must then plug the unit into A/C power, or do a Soft Reset by again, pressing the reset button with the stylus.
Nov 21, 2009 | HP iPAQ H5455 Pocket PC
The picture bleeds down to a black screen. At
Ur main backlight video board is the cause,must replaced.
Oct 25, 2009 | Sanyo DP26746 26 in. LCD Television
Froze and Fading Fast!
i have a nextar x3-08 i got problem like when i start gps then 4 icon display but i click on car icon its getting frozen i can't do anything with it. Another 3 is working like cd,camera,and setting icon. so, please anyone solve this problem
Aug 30, 2009 | Nextar X3 GPS Receiver
There is a Fading strip of white Running across my screen
try resetting your phone factory setting it will help.
Jul 02, 2009 | Nokia E63 Cell Phone
Plasma no picture, fades to black from startup logo
UPDATE:
I finally isolated the problem, the problem has to do with the Y SUSTAINER BOARD not receiving enough/necessary voltage when turned on, while initially thinking it was just the yboard was the problem, i replaced the Y sus board with no success, with only further diagnosis, i discovered the board voltages coming from the powersupply, there are 5 voltages that relate to the Y sustainer board, VA, VSC, VS, VE, VSET. they all supply a certain voltages that all have to be supply the correct voltage in order for the y sustainer board to be working, well guess what, the VA line, which for my set needs 70volts, which upon startup quickly drops from 75volts to a jumpy 8.5-9.5 volts, which of course is nowhere near the 70 volts needed, so this quick drop in voltage is directly related to the screen fade upon startup, i found the problem now the real problem is finding a replacement power supply. hope this helsp anyone with similar issues.
Mar 02, 2008 | Dell W4201C 42 in. Plasma HDTV
Screen keeps fading to white
try doing full factory reset.go to settings,than full factory reset and the code for that is 8 numbers of zeros.
Sep 25, 2006 | Samsung ZX10, E315, E317, P735, E630, D500...
Picture keeps trying to black out
Hi I have seen this problem before, and it was the video processor. I have seen the picture fade to black, then come back, and also fade to green. The cost to repair is prohibitive unless you could find a shop that perhaps has hung on to a unit that was hit by lightning, and only has a blown power supply. The only ray of sunshine I could offer, is if you recently connected your unit to a vcr, because the effect you describe is also what appears when you try to play a dvd that is copy guarded. If your DVD player is connected to a vcr then to the television, take the VCR out of the loop, connect straight to t.v. and all will be well. Goog Luck!
Jul 16, 2006 | Toshiba SD-K741 DVD Player
Nextar X3-08 Car GPS Receiver Logo
417 people viewed this question
Top Nextar GPS Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Nextar GPS Expert? Answer questions, earn points and help others
