Question about Sony Cyber-shot DSC-W80 Digital Camera
Is there a video that show how to short ciruit the battery
Posted by mr_e_bowleg on
electronic & computer repair& servicre
  • Sony Master
  • 12,061 Answers
Why do you want to "Short Circuit" the battery, as if this is done, and as I have experienced, that will often cause them to literally explode! If you mean how do you Flatten a battery, for recharging or similar. Then you use a small 1 OHM 10 Watt. resistor. Or a Torch light bulb. Anything other than a direct 0 OHM circuit, is OK. but like joining the ends of same piece of wire to each terminal, is going to be a bad. experience.
Posted on Apr 06, 2010
What damage can occur if a battery charger is incorrectly attached to the battery and an attemp to start is engaged?
Your electic circuit suffers. Thw more complex the system, the worse is the damage. You atre short-ciruiting your machine!
Oct 09, 2015 | Garden
P1634 Auxiliary Heat Relay - Short/Open
Hi Larry, The scan is showing a fault. the auxiliary relay for the heat control has mal functioned and either the wiring, a fuse or the relay its self is defective. It could also be a short ciruit in the wiring. Regards John
Jun 17, 2012 | 2006 Hyundai Tucson
Cartridge error...refer to device documentation to troubleshoot.....on my 5610 hp printer
In that case, sometime, there might be some dust, so cartridge is not readable;
1. Pls take out your cartridge from printer.
2. For ciruit part on cartridge, wipe out gently with rubbing alcohol(recomand use Q-Tip)
3. Also, wipe out the ciruit part in printer... where cartridges are attached.
4. Put it back your cartridge and c whether it's working.
Otherwise, non of above method not working, your need to replace your cartidge with new one due to "cartridge short"
Apr 11, 2011 | HP Officejet 5610 All-In-One InkJet...
In 30 second full battery is epmty
Either your battery need replacement or your cell phone has a short ciruit inside drawing the power down, contact a cell phone technician for help
Feb 27, 2011 | Cell Phones
No sound and dose not stay on
Here are some quick things that you can check.
-Make sure there is not a short ciruit at the speakers
-Check fuses on the back if available
-Make sure the receiver is in a well ventilated area.
If you go through this and still dont find the problem, than you most likely will need to get it sent in for repair.
Good Luck
Jan 08, 2011 | Onkyo HTR500 Receiver
Electrical trouble
there is a shortage to earth follow a wiring diagram and check all earths on that ciruit
Apr 21, 2010 | 1979 Yamaha XS 500
The middle part on dashboard which is showing the trip is not on. Somethimes i can see it, but the light is not bright enough.
there is a tiny chip on the ciruit board inside the dash that will slowly short out until it will not show any thing the only way to fix is to replace the instrument panel
Oct 10, 2009 | 2001 Buick Regal
I spilled water on my laptop
hi,
since you spilled the water when the laptop was on, the internal ciruits could have been short ciruited. you cannot repair it yourself. please contact a nearby service center. they will give you the information regarding whether it can be fixed or not. but my guess is that it cannot be fixed easily. beacause short ciruits generally blows of the ciruit completely and things like soldering also won't help.
good luck
Feb 06, 2008 | Toshiba Portege 7200CTe Notebook
Sony Cyber-shot  DSC-W80 Digital Camera Logo
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sony Camera Expert? Answer questions, earn points and help others
