Question about D-Link WDA-2320 (ASKU54036) Wireless Adapter
Can't Share Files/Folders over home network
I've had this issue with an old PC and thought it was just an issue of it being an old computer and needing replacement. I have a home wireless network set up and would like to share files/folders over it. My main PC can see the shares of my laptop and can access them no problem, however my laptop can't do the same. The laptop can see the PC in the work group, but I get an "Access is Denied" error if I try to see it's shares. I have tried many different fixes and eventually just gave up. But now I've purchased a new PC. I figured I didn't need a new wireless card since I had one from my old one. I'm getting EXACTLY the same issue with my new PC. The only common denominator is the wireless card. I've updated to the latest drivers. I'm at a loss. I'd rather not have to buy a new card if I don't have to, but I'm thinking it's my only option.
Posted by admiralknigh on
Dave King
  • 1,606 Answers
That sounds more like the security settings on the pc are not set correctly. Should be nothing to do with the card or the laptop. This is just a windoze thing.
Share a drive or folder on the network To share a drive or folder on the network
  1. Open Can't Share Files/Folders over home network - shortcutcold.gifWindows Explorer, and then locate the drive or folder you want to share.
  2. Right-click the drive or folder, and then click Sharing and Security.
    • If you are sharing a drive, on the Sharing tab, click If you understand the risk but still want to share the root of the drive, click here.
    • If you are sharing a folder, go to the next step.
  3. Do one of the following:
    • If the Share this folder on the network check box is available, select the check box.
    • If the Share this folder on the network check box is not available, this computer is not on a network. If you would like to set up a home or small office network, click the Network Setup Wizard link and follow the instructions to turn on file sharing. Once file sharing is enabled, begin this procedure again.
  4. Notes
    • To open Windows Explorer, click Start, point to All Programs, point to Accessories, and then click Windows Explorer.
    • When you share a drive or folder, anyone who has user access to the network can read the contents of that drive or folder. If you want to remove the drive or folder from the network, follow steps 1 and 2 above to get to the Sharing tab. On the Sharing tab, in Network sharing and security, clear the Share this folder on the network check box.
    • To allow complete access to the contents of your shared drive or folder, follow steps 1 and 2 above to get to the Sharing tab. On the Sharing tab, in Network sharing and security, select the Allow network users to change my files check box.
    • To change the name of your folder on the network, in the Share name text box, type a new name for your folder. This will not change the name of the folder on your computer.
    • If you are logged on as a guest (a guest account provides access to the computer for any user who does not have a user account on the computer), you cannot create a shared folder.
    • The Sharing option is not available for the Documents and Settings, Program Files, and WINDOWS system folders. In addition, you cannot share folders in other user's profiles.
Posted on Apr 05, 2010
HP1020 problem with a livebox and WIN7 configuration
I found it somewhat difficult to completely Unshare files and folders on my HomeGroup Network and still allow Printer sharing in Windows 7 (Home Premium).
Initial UnSharing still allowed files like those below to be viewed on other home network computers:
C:/Users/
{user x} (folder)
AppData (folder)
Default (folder
Public (folder)
desktop.ini (file)
Other computers on the home network could step through many levels of hiarchy in the AppData folder and appeared to have "Delete" access!!
To completely decouple the computers, I had to go through the following several different Sharing/Unsharing assignment locations, till I could completely break the linkage.
I would appreciate any clarifications or simplifications.
File UnShare Confusion on HomeGroup Network
There are several different Network Sharing/Protection assignment locations in Windows 7.
To prevent all sharing between computers on the Homegroup Network, but allow Printer Sharing:
1) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options.
Uncheck sharing boxes that you don't want to share. Save changes.
2) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Click "Turn off Public folder sharing (people logged on to this computer can still access these folders)".
3) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Choose Media streaming options.
Click "Block All" button. Turn off. Click OK.
Anomaly Note: You have to close Control Panel and repeat all step 3 again for the change to take effect.
4) Open Windows Explorer.
a) Select "C:/", select "Users" folder with single click, then click "Share with" in toolbar.
b) Select Advanced sharing.
Under Sharing tab, select Advanced Sharing. Uncheck box labeled "Share this folder". Apply and close.
5) Open Windows Explorer.
Select "C:/Users/", select all folders and files under "Users", then click "Share with" in toolbar, then click "Nobody".
6) Verify success by going to other home network computer(s) and trying to access your files and folders. You should only be able to see there is a computer and not be able to see any folders of files.
smooth printer service
Dec 16, 2012 | HP LaserJet 1020 Printer
Tip
Sharing Your Own Computer's Stuff with the Network
To share a file or folder with your fellow computer users, move the file into your Shared Documents folder, which lives in your My Computer window. (You must move or copy a file into the Shared Documents folder; shortcuts don't always work.)
After you place your file or folder into your Shared Documents folder, it appears in the Shared Documents folder of everybody else using your computer.
Administrators can share folders without having to move them into the Shared Documents folder. The trick is to follow these steps:
1. Right-click on a folder you'd like to share and choose Sharing and Security from the pop-up menu.
Open My Computer and right-click on the folder you'd like to share. When the menu appears, select Sharing and Security. A window appears, showing the Properties for that folder. It opens to the Sharing tab.
Right-click on a folder and choose Sharing and Security to share the folder on the network.
2. Click the box marked Share This Folder on the Network.
A check mark in that box lets everybody peek at, grab, steal, change, or delete any of the files in that folder. To let visitors look inside the files but not change them, remove the check mark from the box marked Allow Network Users to Change My Files.
3. Click OK.
Now that particular folder and all its contents are available for everybody on the network to share.
Sharing a lot of folders isn't a good idea because it gives network visitors too much control over your computer. Even if you trust people, they might accidentally mess something up. To be safe, only share files by placing them in the Shared Document folder.
Inside Shared Documents live two more folders, Shared Music and Shared Pictures. Those two folders are also available to any user. So, if you want to share documents with any user of your computer, store them in the Shared Documents folder. When you make MP3s from your CDs, store them in the Shared Music folder, too, so that everybody can enjoy them.
on Dec 01, 2009 | Computers & Internet
Can i pair my hp laptop to my samsung R480 laptop
It depends on what you mean by "pair" If you want to transfer files, you should be able to do so through either your wireless or ethernet connection. Hopefully you have a connection both computers can use at the same time. Make sure both are in the same workgroup, both have file sharing set up, and decide which files you want to share, copy, or whatever. Go to start, control panel, then system. Then click on computer name tab. Change one or the other so both have the same workgroup, but different computer names. If you change workgroups, you will have to reboot. You need to have sharing set up – decide which folders you want to share, and click on “share this folder”. You will get a warning, and will have to say “ok” to enable sharing.
Now click on "network places" icon, if it is on your desktop. If it isn't, then go to my computer, and click the arrow to go up one level. Network places should be there. Click on "entire network", then on "Microsoft windows network" then on "mshome" or whatever your network is called. You should see at least two computers there. You cannot have two computers with the same name in a network, by the way. If both are in the same workgroup, and both have sharing set up, you can double click on both and shared folders will be there. It is easiest to arrange the two folders side by side. Within those folders are the files you want to share, or copy. Simply select the files, and drag them to the other computer.
Aug 22, 2010 | Computers & Internet
My Advent 4211 netbook connects wirelessly to the Internet through my Desktop and a Belkin router. How do I allow the netbook to see the files in the desktop?
if you ran your network wizard to get the internet access shared then you should be able to share your files too.
and folders the same way ,
go to my network device,
veiw network computers,
if you can see the computers desk top then
go to Shared folders and try to see if your folders have been shared open something.
If you can see the desktop and not open the shared folders then run the network wizard again,shutdown and restart,to save your settings,
to share files between both machines you will need to drag the file into my shared folders or rightclick on the file your sharing and click on sharing,follow the prompts to share and that should fix your problem.
Please rate me thanks MISTERDJ
Aug 16, 2009 | Advent 4211c Notebook
How to set up uverse home network with 2wire gateway
To use AT&T Uverse for a home network, you need to get the AT&T "Homeview" Network Management software. AT&T provided this software in the past freely.
This software must be run on each PC on your home network, and then each PC can see the others. You then use go to My Computer, select each disk drive you want to share, right-click and select Sharing and Security, and select to share the drive. Then go on the drive to the folders you want to share and right-click and set them to be shared. Then the Homeview system will show these are shared folders. You can also share printers on the same network using the Homeview software.
Jun 13, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Cannot share files/folders with home network...
Bill,
I understand the frustration and I will try not to add to it. I did a bit of searching and found one thread on another forum that was similar to your situation. This person said the following:
The solution was simple:
I was running NORTON 360.
Under firewall settings; disable personal firewall.
Once this is done, access is allowed to the host pc.
You can then set your permissions, create network paths and map network drives like you would normally do.
Bill, I can't tell you this will solve the issue but it did for this person.
Good luck
Apr 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Can't share files/folders between networked computers...
I can answer this but I'm kinda winging it so you will have to figure some of this out for yourself.
By default, XP does not let you share your data over the network. Go into folder properties and enable simple folder sharing.
Go to control panel/network and enable file and printer sharing for your network adapter. Reboot and go.
Mar 31, 2009 | Datamax Power Supply (120 VAC with Power...
I am trying to set a network using a wired desktop and a wireless laptop (desktop using XP and laptop using Vista)I am using a Linksys WRT160N, I can get on the internet with no issues at all but when...
in the router's lan (not wan) configuration - set the dhcp server (gateway address) to be 10.1.10.1. Then set the addresses of the clients (connected to the router) to be assigned addresses from 10.1.10.10 - 10.1.10.20. Set the desktop's TCP/IP address to be 10.1.10.11 (static) with a subnet of 255.255.255.0, and a gateway address of 10.1.10.1. Set the laptop's wireless connection (TCP/IP adapter) to have a static 10.1.10.12 address with same subnet mask and gateway address of desktop. Change the workgroup on both computers to be of the same name (case sensitive here) to a name such as HOMENETWORK. Then on each computer, open up "My Computer" and right click on folders, files or printers that you want to share on your network!
Sep 26, 2008 | Computers & Internet
File sharing
it is possible
If you have multiple computers in your home and they are connected through a home network, you can share files among your computers. That means you no longer have to copy files to a floppy disk or USB flash drive to transfer them to another computer. Once you configure your computer to share files, you (or another user with the appropriate permissions) can, by using Windows Explorer, open them from other computers connected to the network, just like you’d open files that are stored on a single computer. You can also choose to have folders visible—but not modifiable—from other computers on the network.
To share files on your computer with other computers on a network, you need to:
Share a folder on your computer. This will make all of the files in the folder available to all the computers on your network (you can’t share individual files).
Set up user accounts on your computer for everyone who needs to connect to your shared folder. If any of the accounts are Limited User accounts (unless an account is a Computer Administrator account, it is a Limited User account), follow the steps in Set permissions for files and folders to enable them to open your files.
To access shared files that are on another computer on your network, you need to:
• Connect to the shared folder from other computers on the network. This procedure is described in Map a network drive.
Note: By default, file permissions only allow your user account and administrators on your local computer to open your files, regardless of whether a person is sitting at your keyboard or at another computer. It may help to keep these three things in mind when setting up file sharing:
• Files have user permission settings.
• Every computer has its own user database.
• Some accounts are administrator accounts and some aren’t.
Configure your computer to share files To share a folder on your computer so that files stored in the folder can be accessed from other computers on your home network
1.
Log on to your computer as an administrator. For more information, see Access the administrator account from the Welcome screen.
2.
Click Start, and then click My Documents.
68599-click-my-documents.gif 3.
Right-click the folder that you want to share, and then click Sharing and Security.
68599-click-sharing-and-security.gificotip.gif Tip: If you want to share your entire My Documents folder, open My Documents, and then click the Up button on the toolbar. You can then select the My Documents folder.
4.
If you see a message that reads, As a security measure, Windows has disabled remote access to this computer, click the Network Setup Wizard link. Then follow the instructions in How to set up your computer for home networking. On the File and printer sharing page of the Network Setup Wizard, be sure to select Turn on file and printer sharing. If you do not see this message, skip this step and go to step 5.
68599-click-network-setup-wizard.gif Note: If you do not see the Network Setup Wizard link or the Share this folder on the network check box, your computer probably has Simple File Sharing disabled. This is a common change made to computers used for business. In fact, it happens automatically when a computer joins an Active Directory domain. You should follow these instructions to share a folder instead.
5.
In the Properties dialog box, select the Share this folder on the network check box.
68599-click-share-this-folder.gif 6.
If you want to be able to edit your files from any computer on your network (instead of just being able to open them without saving any changes), select the Allow network users to change my files check box.
68599-click-allow-network-users-to-change-my-files.gif 7.
Click OK.
68599-click-ok.gif Windows Explorer will show a hand holding the folder icon, indicating that the folder is now shared.
To connect to the shared folder from another computer, follow the steps described in How to map a network drive.
Note: By default, only you and other people with an administrator account on the computer sharing the folder will be able to open your files. To limit access of specific users with an administrator account on the computer sharing the folder, read How to set permissions for files and folders.
Aug 14, 2008 | Microsoft Windows XP Professional
D-Link WDA-2320 (ASKU54036) Wireless Adapter Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
k24674
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
