It's been 3 years since I got this branded (LG) PC. I have had no problems until the past 3 weeks, when I started noticing this bright blue-greenish (turquoise) circles appearing on the left hand corner of the monitor and increasing with usage time. It kinda spreads all the screen at times with bright light mixing up colors. It is pretty on and off. I would also like to mention that my UPS (backup battery) has been not working since over 4 weeks and I have directly connected the system to the power socket. I am unsure if this problem is due to the infrequent power voltage or if there is really a problem with the monitor itself..
Pls help.. Ur valued suggestions would matter..
SOURCE: reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
SOURCE: Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Check WGA if it is correctlly put on and go to DISPLAY PROPERTIES - SETTINGS - ADVANCED -MONITOR
