Dell E173FP 17" LCD Flat Panel Monitor Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor screen goes blank at intervals. If I turn
Monitor screen goes blank at intervals. If I turn the monitor off and then on the screen returns like before.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Apr 06, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366133
Points
33650
You may have to open it up and look for bad soderling works, see my pictures to see what bad solderign joints look like. Also check fuses, connectors, etc.
See what goes wrong with Dell monitors here:
http://s807.photobucket.com/home/budm/allalbums
I assumed that it does the same with other PC also.
2answers
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
5helpful
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
1helpful
MONITORS TURNS BLANK OCCASIONALLY AND THEN COMES SPONTANEOUSLY BACK TO NORMAL. ONCE THE IMAGES STARTED FLICKERING. I HAVE THE IIMPRESSION THAT THE MONITOR NEEDS TO "REST".. THE TURNING BLANK HAPPENS...
it seems to be the power management
right clik on desktop click properties
click on screen saver tab
and from there click on power
ther you can adjust monitor stanby mode
Viewsonic VA721 - Screen goes blank for second or two and returns
Sounds like its going to sllep too soon make sure you do not have it set in your video card settings. also try it on a diffrent computer. if that does not shore it up replace the acpi board
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
