NetTV PDP42V Television Logo
Question about NetTV PDP42V Television
What is the symptom of your Tv if yppd is not properly working?
Posted by allenbarlaan on
Plasma tv no picture no sound blown fuse fs2
The problem here is you cannot even find that---I suggest you either buy the y sustain board as only circuit boards are sold and NO parts themselves or take it to a shop for an estimate.
Hi, Please somebody help me. I repair a faulty grundig plasma tv. At first it has no picture because the STK795-820 (YPPD) IC and the fuse was broken. I changed these and now it works, but the picture is...
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
2helpful
HP PL4260N 42 in. HDTV Plasma Television Problem. there isn't picture or sound, i believe the part i am looking for is: p n 3501000201a sn sa06296537
The problem is with the YSUS board. Also 1 or two fuses (4A) will be blown so you will need to replace those along with the YPPD-J018C Hybrid IC module that is under the large heat-sink. I'm an EE in my day job so I have done this sort of repair from time to time but it can be intimidating unless you have very good soldering skills and a good solder station such as a MetCal. You will need a lot of heat to free the pins before prying this IC up. Failure to do it correctly may lift some of the delicate traces and the new part will not work! When removing the IC I always add leaded solder on these lead-free boards because it flows better. Also adding extra flux and using a Soldapullit Solder Tool works well. You keep adding the solder and sucking it back up...until the pins are relatively clean. Removing the IC still took me about 1/2 hr. to get enough solder sucked up until I finally was able to stick a screwdriver under it and pry it up. Do this gently, on several places on the IC to break it loose. On my board Q1 was blown but since there 4 of these same little semi-conductors, your problem might be Q2, Q3, or Q4? They are easy to spot because they blow apart catastrophically, there was black soot around mine. Also, one of the main reason this part failed is because the white heat sink grease was dry. This means that the heat-sink was not able to adsorb the heat from the board as well anymore and then it just got too hot and failed. So use a good high end thermal grease when you put the new YPPD-J018C part back on the heatsink. Something with silver like Artic Silver will cost about $10.00 a tube. This will make the TV last much longer. The YPPD-J018C part should run you anywhere from $39.95-$49.95 plus shipping. Both Suburban Electronics in MD. and Rich-Tech have the part. Good luck!
4helpful
2answers
Some troubleshooting help please.
The part that caused the fuse to blow is the hybrid that is mounted underneath the heatsink on the YSUS and ZSUS boards. The part used on these boards might be YPPD-J017C or YPPD-J018C, in about 90% of the time, replacing these hybrids fixes the plasmas with no video but good audio. Since VS and GND is shorted, that means that the hybrid has shorted internally. Most service techs would rather replace the entire YSUS or ZSUS boards since the hybrids are very difficult to remove.
Let me know if you require further assistance.
3helpful
2answers
When i turned on the TV today (it worked last night fine) I had sound but no picture. I could not even get the menu for the TV to appear
The problem is with the YSUS board. Also 1 or two fuses (4A) will be blown so you will need to replace those along with the YPPD-J018C Hybrid IC module that is under the large heat-sink. I'm an EE in my day job so I have done this sort of repair from time to time but it can be intimidating unless you have very good soldering skills and a good solder station such as a MetCal. You will need a lot of heat to free the pins before prying this IC up. Failure to do it correctly may lift some of the delicate traces and the new part will not work! When removing the IC I always add leaded solder on these lead-free boards because it flows better. Also adding extra flux and using a Soldapullit Solder Tool works well. You keep adding the solder and sucking it back up...until the pins are relatively clean. Removing the IC still took me about 1/2 hr. to get enough solder sucked up until I finally was able to stick a screwdriver under it and pry it up. Do this gently, on several places on the IC to break it loose. On my board Q1 was blown but since there 4 of these same little semi-conductors, your problem might be Q2, Q3, or Q4? They are easy to spot because they blow apart catastrophically, there was black soot around mine. Also, one of the main reason this part failed is because the white heat sink grease was dry. This means that the heat-sink was not able to adsorb the heat from the board as well anymore and then it just got too hot and failed. So use a good high end thermal grease when you put the new YPPD-J018C part back on the heatsink. Something with silver in it cost about $6.95 a tube. This will make the TV last much longer. The YPPD-J018C part should run you anywhere from $39.95-$49.95 plus shipping. Both Suburban Electronics in MD. and Rich-Tech have the part. Good luck!
15helpful
6answers
No picture, audio OK, HP PL4260N, outside HP's repair for common Problem. According to HP and your site the Y sustain board needs replacing, problem supposedly is plasma mal discharge.
I had the same problem and HP has been very helpful, try calling this number 877-917-4380 ext. 79 and be firm tell them this needs to be fixed. They are sending my second replacement part and said they will keep sending parts till it works, this tv is almost 3 years old.
2answers
How to adjust picture on projection TV
It should have in the menu ,under settings ,, convergenge,, it realines the colors,, ,,
MT42PZ10 LG plasma
I have the ic in stock,, it is 69 dollars.
I have a Vizio P50HDM. The old "pop of death" occurred again which is the second time in less than two years. The repair shop replaced the y-sus board the first time but I am being led to...
Hi, i just got thesame problem as you do! The zsus board situated at the left corner when behind the tv is usually the cause. Apparantly the Hybrid IC yppd-j015b could be damaged since it is the recipient of the approx. 192v DC. There is a fuse which protects it, but at times goes off with it. It is usually caused by overheating and in my case, i took a closer look underneath the Hybrid IC and found tinny 'tainted sparkles' on the heat sink which was caused by one SMD (surface mounted device)capacitor. This caused a spark, or what many call ''POP OF DEATH'' ,- a short circuit , 192V TO GROUND, the heatsink!
Infact, when the person who owned the tv complaint of hearing a pop sound, when i opened the tv myself and switched it, i could see that it came on, there was sound, faint picture exactly as you described but as i was gazing, i SAW the spark, again but this time even the faint picture disappeared.
It was a good thing that i saw the spark! Now what had happened was that the first pop did blow up low value smd resistors and MOSFET smd in the Hybrid IC yppd-j015b but kept the tv on with no picture so the second time i saw the spark made matters worse, the fuse went off and other MOSFET sms (s).
Now in all of this, you have to have more than basic knowledge of electronic repairs to even start opening the tv because of many reasons:.Anti static components, MOSFETs,etc just to remove the yppd-j015b hybrid ic without the proffessional desoldering equipment, feels like battling with a puckupine! Because of lack of proper desoldering equipment, most technicians advice people who dare try to REPLACE the Z SUS and Y SUS boards.
If you can, just make sure you replace the bad parts yppd-.... included and place anti heat isolation underneath the ic or add two more super quiet fans to cool off.
NOTE
Before replacing parts, take very close looks at the surrounding parts for physical damages and test if not all resistor and diodes arround for shorts.
regards
paul
Open Questions:
Top NetTV Televison & Video Experts
Marvin
Marvin
Are you a NetTV Televison and Video Expert? Answer questions, earn points and help others
