Where can I find a solution for Gateway keyboard KB-0401 that will not work with Windows 7- the driver is outdated, and I can't seem to find a driver update on it anywhere.
SOURCE: Gateway cordless KR-0401 Keyboard
I had the same problem. I solved it by pressing the connect button on the back of the keyboard and then pressing the connect button on the wireless connection base. The keyboard and the base will sync up again. Should solve your problem.
SOURCE: Gateway keyboard shift key creating special characters when used
|I have been having the same issue with this keyboard since it was fresh out of the box. Unfortunatly, I replaced it right away with an ergonomic keyboard & didn't think about replacing it. Now that the ergonomic one is busted, I'm stuck with the factory one again with the same problem. I contacted Customer Support & they told me that it was a faulty keyboard & should be replaced. So, basically, there isn't anything you can do but go out & get a new one. If you are still within the one year warrenty, Gateway will replace it for free, so you'd better test out those keyboards right away & replace them immediately if need be!
-mazy
SOURCE: cut, copy, and paste keys
You may want top try this? I did not work for me but with some luck and hope it works for you.
http://support.gateway.com/s/issues/2-1889658510.shtml
Best of wishes and take care!
SOURCE: keyboard driver
gateway.com has a driver page with the drivers for everything they've ever pumped out
SOURCE: Light on gateway keyboard kb-0817 where is it or
There are no lights are the less expensive keyboards that are shipped with many Gateway computers. They have a more expensive keyboard that does have lights. Suggest you get that one or some other keyboard with lights already included.
