Question about Konica Minolta Minolta FAX3900 Digital Copier, Copier/Fax Machine 16 ppm printing and up to 600 dpi resolution, rec... Printer
Konica Minolta Fax 3900 showing Error C0500 after power outage. Is there a way to reset the machine?
Posted by amyborders on
just me
    New Friend:
  • 60 Answers
1. Turn the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON and release STOP after 5 seconds.
Posted on Feb 25, 2011
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
How can I reset eror code CO 500 on konica minolta copier DI 2510
Aug 08, 2016 | Konica Minolta Di2510 Di251 Di250 Di2010...
How do I change a Drum Cartridge in a Konica Minolta Fax 2900 / Fax 3900?
toner and drum are separate the toner attaches to the drum unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 20, 2014 | Konica Minolta Minolta FAX3900 Digital...
ERORR C0500
Sep 26, 2013 | Konica Minolta Office Equipment & Supplies
How do I change the date stamp on my fax machine?
just change the date under utilities, initial user data, date& time
Jul 13, 2010 | Konica Minolta Minolta FAX3900 Digital...
Minolta Fax 3900 problem at work
I have a Minolta Fax 3900 and it at times while trying to send a fax will say *tx cancel* and only send 2 pages of a fax. It appears like it does send the fax but it might not be the complete fax. I can't cancel the fax or stop it either. Does anyone know how to fix this problem.
Apr 22, 2010 | Konica Minolta Minolta FAX3900 Digital...
Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Oct 10, 2008 | Konica Minolta DiALTA Di200 Copier
550 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
