Question about Polaroid TDA-03211C 32 in. LCD HDTV
My 32in polaroid tv completely lost power/no indicator light, totaly no power
Posted by richardhaes on
Anonymous
    New Friend:
  • 7 Answers
The problem is with the power supply. Try here to get the right extra part for your model
polaroid tv parts
Posted on May 31, 2010
Darren Law
  • 131 Answers
Please use the following link for a possible repair....
http://www.ohmsupplies.co.uk/epages/62027733.sf/en_AU/?ObjectPath=/Shops/62027733/Products/REP76
Posted on Apr 05, 2010
Reset dynex tv
You can reset the unit by unplugging, wait 30seconds to 1 minute.then try again.
If still doesn't come on, the lightning may have done some internal damage, such as to the power supply or Main PCB.
Jul 23, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Sharp flatscreen tv does not turn on
If the front panel indicator lights, power is getting to your TV. If nothing happens when you turn it on, it is likely that the internal power supply has failed
Jan 04, 2013 | Sharp 75006932 LK315T3LZ41C 32in LCD Panel
Tv turn on no picture
If the sound still works normally but the screen is dark then I would suspect the inverter for having the issue. If you dont have sound either then I would check both the power board and the main board.
Oct 20, 2012 | Polaroid FLM-3734B 37 in. LCD HDTV
Where is lamp location in polaroid 32in hd tv
Your model is a LCD flat panel which doesnt have a lamp. Instead they have a series of flourescent tubes behind the Screen which light the screen. The backlights hardly ever fail its usually the Inverters which fail when you dont have any picture with that model. You can get the inverter board and free technical assistance from www.tvrepairworld.com
Aug 03, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
I was given a 32in Polaroid tv, the model # is TLX03210B, I need a remote and a manual. calling the 888# should be able to help me.
Try polaroid website itself to down load and print it ur self,if ur tv model still in the market.Or call their customers service phone number pay a fee.They'll sent it to u.Try website like Remotes.com to buy an original remote.
Mar 22, 2011 | Polaroid 3211TLXB 32 in. LCD Television
Tv struck by lightning and will not turn on. Can it be repaired or is it a lost cause?
Yes,it repairable.The tv have power at all like the LED power light indication flashes?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.No power LED light indication all.The power supply board is dead and also the Tuner signal board is dead.Must replaced both boards.
Oct 16, 2010 | Polaroid FLM-3232 Television
My 32In hdtv from 2007 turns on just fine then flashes polaroid and doesnt respond after that. Wats wrong?
My 32in hdtv turns on, flashes Polaroid and shows there is no signal then turns off, what could the problem be?
Jun 12, 2010 | Polaroid FLM-3232 Television
Polaroid TDS-03211C 32in LCD TV/DVD Combo
check the fuse right next to the plug on the set if thats not bad then your power board has bit hte dust
that model has so many differant supplies it is hard to say what diode has gone or wheather it is just a bad puffy capacitor
Sep 22, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
No power on
is the status light on wheather red or blue if eather one then the fuse is fine if not check the fuse. if the lights are on then chances are your caps are gone its a huge problem with these tvs. if it is your caps than just replace them as i did and the tv is working like new again. These are the caps I replaced they where only a little swollen I was worried if they where even the problem but I changed these three and was very happy that my TV is now working like new again the two top ones I replaced with 1000uf 16v the lower one is 1000uf 35v ok well I hope this helps ya
Dec 19, 2008 | Polaroid FLM-3225 32 in. LCD Television
Polaroid, 32in, HD LCD.
32 flat panel polaroid will not turn on
Oct 02, 2007 | Televison & Video
Polaroid TDA-03211C 32 in. LCD HDTV Logo
309 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
