Question about Nordic Track NordicTrack Treadmill, A2550
Nordic Track A2250 Pro stuck inclined
My Nordic Track A2250 Pro is stuck in the incline position. There was a knocking noise coming from the rear left (when on the machine) corner. I tried to fix this by recalibrating the incline. I followed the instructions in the manual, but the machine never declined. I've tried recalibrating many times, but it never attempts to move. Now it won't even move the belt. Any ideas?
Posted by fools11 on
  • diverdiva1_p
    diverdiva1_p Mar 19, 2013
    I know this is an old post , but this is exactly what is happening to me. What the repair costly or easy fix?
  • Anonymous Apr 01, 2014
    Nordic rack elite 5700 noise when incline or delince
trslugger74
    New Friend:
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Posted on Feb 13, 2011
Steve BUckley
    New Friend:
  • 4 Answers
Buckmanservices.com an online Fitness Diagnosis company.. they have 24/7 techs ready to save you money they only charged me $30 they saved me hundreds..I recommend them for sure
Posted on Jun 13, 2012
My Nordictrack treadmill model T7si is stuck on the 10 incline position. How do I fix it?
Check that the incline plus switch is not jammed or likely there is a defect in the panel circuit causing plus incline to be repeated. This needs to be trouble-shooted by removing and testing the panel circuit.
Oct 07, 2014 | Nordic Track Exercise & Fitness
Nordictrack 3700 makes a knocking sound when I run on it
Hello.
Knocking noises more than likely come from the rear roller, there could be a small chance it's coming from the motor it's self though.
Have some walk on the machine and make the noise while you locate which end of the treadmills coming from.
If it is the rear roller the bearings will need to be replaced, this can be done by removing the rear roller and taking it down to any bearing shop and have them locate the bearing numbers. Ask them for advise on removing them as well.
If the noise is coming from the front of the treadmill then have a look at the fly wheel coming off the motor, locate grub screws and tighten.
GymWorld.net.au
Jan 11, 2014 | Nordic Track Nordictrack Track E 3700...
C2250 treadmill incline recalibration - incline goes up, not down
Plug the power out and plug it back in after a count of 50 could be that it needs to be reset .then plug back in the power and see what its doing if no luck go to manual and look for reset
Jan 06, 2014 | Nordic Track Exercise & Fitness
Why does my Nordic Track Reflex 4500 Pro incline automatically when I start it up?
You must tried again the s.calibration, for easy diagnose, and troubleshooting.
However you must Adjust the speed sensor, test it, clean it, and tight any plug or connector, see the diagrams attached and proceed according.
2) Lube the elevation motor, the shaft + gear, test the motor itself for open or short. see the diagram attached. If you machine use RELAIS test it for dirty, or open and repair.
God bless you
Nov 27, 2012 | Nordic Track NordicTrack Reflex 4500 Pro...
Nordictrac a2250 beeps when key is attached
adjust the reed switch first, and after RUN the software calibration for diagnose and troubleshooting. see the diagram
God bless you
Jun 17, 2012 | Nordic Track NordicTrack Treadmill, A2550
Incline goes up and down
I had the SAME problem, several time, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Apr 24, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
Oct 22, 2009 | Nordic Track Exercise & Fitness
Incline stuck- keep going up and dopwn. Treadmill
I had the SAME problem, several times, with my NordicTrack A2250 Treadmill.
Oct 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Treadmill, A2550 Logo
2,163 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
