Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
TOSHIBA TV NO PICTURE
NO PICTURE AFTER A LOUD NOISE,BUT DOES HAVE SOUND, TOSHIBA MODEL NUMBER 46H83
  • Anonymous Apr 05, 2010
    There is picture when a DVD is played....if this makes any difference.
Anonymous
    Scholar:
  • 137 Answers
Sounds like blown invertor board that powers the backlights (if it is LCD or PLASMA). If your lucky and its just the invertor board blown it could cost anywhere between £50-£150 for new board (without labour).. if you are UN-Lucky, then the backlights themselfs may have blown which is *usually* an un-economic repair.
Posted on Apr 05, 2010
    Then are you sure that the TV made the loud noise and not the digibox? If the tv is working fine when you put a DVD player through it, then I wouldn't think there is much wrong with TV, as the Digibox (freeview or sky) basically use the same (scart) connections, so should work the same.
    If however it is a dvd player that is built in to the TV thats working, and all external sources have no picture, it could be a blown video decoder chip (unlikely as the internal dvd player would probably use the same chip)...
My phillips is making a loud buzzing noise, no picture, then it shuts off
presuming it has one two choices: contact Philips (good luck there) or Google the model number with "color wheel"
2helpful
The toshiba 46h83 46in rear projection tv comes
the red flash you are talking about im assuming is the screen going red
that usualy means a red picture tube they break down
one way to tell turn the red screen control counter clockwise and see if you can control the tube gain
and then you can lightly tap on crt neck and i do mean carfuly and see if it flashes it most likely will and you would need to change the crt and reset it up
Turned on tv have sound but no picture. toshiba 46h83
Most likely your convergence IC's are bad along with the two 5 amp pico fuses on the board to the left up front.
1helpful
2answers
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Toshiba 46H83
Anthing could have happened from a blown fuse to a transformer. Dont tinker with it from the the outside get a repairman out there asap.
Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
2answers
Toshiba 46h83 tv projection not full orizontal pic
if you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
