Question about Sharp AR-5320 Black and White Copier
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE
Posted by midou12345 on
suhail aabed
  • 109 Answers
Toner type error
replace the toner cartridge
Posted on Apr 08, 2010
1 Related Answer
Anthony Karuku
  • 268 Answers
SOURCE: AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Posted on Mar 30, 2010
My sharp machine ar 5516s is having problems giving error code l and 4 simulteniously what can i do
can be the main motor locked if its l4-01 but if its l4-31 its fusing fan locked detected or l4-35 its PS fan locked detected
Jun 18, 2014 | Sharp AR-275 Copier
i hope its L4.If it is showing
L4 it means the main motor is locked(failing to move) Check all the moving parts including the drum unit, developer unit, main drive unit and fuser unit if they are moving freely. If they are moving freely change the main motor
Jun 18, 2014 | Sharp AR-5320 Black and White Copier
What code do i use to clear toner alarm indicator
it can't be cleared until you change the toner sensor
Jun 07, 2014 | Sharp AR-5516s
The printer Ar-5516 is showing H4 error
this error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 04, 2012 | Sharp AR-5316 Advanced Digital Imager...
F2 40 error code on Sharp 5516s copier
you must use ar-202 developer.205sd used for 5516 or 5520
May 23, 2010 | Sharp AR-5320 Black and White Copier
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
2,114 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
