Question about Kohler Home
Kohler Whirlpool K-1266 (Does not star
Kohler Whirlpool K-1266 (Does not start the jets) Hear a humming sound with the motor when turned on but pump does not start.
Posted by vasu_kolli on
Anonymous
  • 155 Answers
Here are some possible causes and solutions. I know some seem simple but am trying to cover all base
  1. Jets Closed, rotate Jet trm ring counterclockwise to open.
  2. Jet not installed correctly, re-install jet, check for 'O' ring damage.
  3. Jets are blocked, Check for blockage and remove.
  4. Pump is not priming, Pumps with wooden support blocks only, Pump shimmed to high, lower pump support bracket. (wooden support blocks only)
  5. Pump is air locked. Loosen fitting on pump outlet to allow any air to escape, re-tighten.
  6. Air Actuator tubing is disconnected, loose, kinked, plugged or damaged. Connect, straighten, clean or replace air actuator tubing.
  7. Air Actuator does not work, replace the air actuator
visual check to see if pump is turning when motor is is on. If not replace the the pump you may need to disconnect the the inlet/outlet to see. I hope this helps at least provide some direction. Good Luck, Jeff
Posted on Apr 05, 2010
New homeowner. Kohler airjet Master tub after hitting power button only stays on for about 20 seconds. Home inspection working fine I believe
put your ear to the side of the tub and momentarily turn on the jet pump, if you hear a humming sound then you need to replace the pump motor capacitor.
Jan 07, 2016 | Home
Whirlpool only hums
Motor is either seized or something is stuck in the pump.
Oct 19, 2014 | Eljer Home
Kohler whirlpool type tub will not pump water out of its jets or take water into the intake. Pump appears to operate fine. Water does not want to move. Suggestions?
When a bath pump turns on but does not move any water it is usually because there is an Air Lock and needs to be released.Try this.
  • Fill the tub with water
  • Turn the pump on
  • Unthread the discharge pump union until water starts to squirt out
  • when this happens you should hear a big 'swoosh'
if the bath pump starts to discharge water through the jets then you have solved the problem.
Rod
us parts center
888-521-6183
Apr 05, 2013 | Kohler Home
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
Hello, My whirlpool has power, the motor hums when you push the button, but no bubbles are coming out. I have checked the 1/4 inch vinyl hose and it appears to be connected. Should I take the round cover...
when a motor just hums when you turn it on is usually an indication that the motor is bad. it has stopped on a flat spot on the windings and will not turn from that spot. if you could turn the motor then the it will probably start but sounds as if you really need a new pump.
Jan 06, 2011 | Kohler Home
My Aqua Glass Whirlpool tub has stopped working. The motor comes makes a sound when I turn it on but the jets are not working
Your motor is shot. you need a new pump. If it comes on and you can hear a hum then it is bad. If you can get us a model number of the pump we can recommend a replacement model for you.
US Parts Center
Jan 05, 2011 | Whirlpool Safety Bath Walk In Bathtub -...
Pushed button to turn on whirlpool - hear motor - jets don't work
if the motor just hummed then it is likely a bad motor. you will need to replace the pump at that point. Bathtub buttons like the one you have either works or they do not. there isn't any in between areas.
May 31, 2010 | American Standard Cadet Corner Bathtub -...
Kohler whirlpool jets not working
Hi there
if the motor hums it is more than likely shot sounds like the brushes went out in it the best thing that could be done would be to either have the motor fixed or replaced
May 18, 2010 | Home
No whirlpool jets
It sounds like the motor needs to be lubricated or there is debris keeping the impeller from turning without the help of a littl force. I would have a professional that deals with whirlpool tubs come and lube the motor.
Mar 20, 2009 | Home
How to identify make and model of old whirlpool tub?
This is a problem common to all whirlpool/air jet style tubs. The pumps become air locked due to the water evaporating from lack of use. All tubs need, and have, SOME means of priming the pump, this is most likely what the problem was, originally, for you. This time in particular you found it to be electrical in nature but for future reference, for you and all who have these style of tubs, I am putting this out there. Some where on the tub, usually along the top edge of the tub is a vent knob that controls the amount of air that the pump is allowed to mix with the water for the jets, usually by closing this valve all the way (tub needs to be full of water of course) and running the pump for a minute or 2, you should be able to get the pump pumping water again, if not you may need to do something else with your particular set-up to get it purged of air, the pumps in jacuzzi tubs are designed to pump water, not air, so if the motor is running but you get no jet action, your most likely air locked and need to prime pump/purge air.
Sep 22, 2008 | Home
Home Logo
682 people viewed this question
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
