Washing Machines Logo
Anonymous Posted on Apr 05, 2010
Replace belt on Hotpoint Aquarius WM31 washing
Replace belt
Barry Coates
Level 3:
  • Hotpoint Master 3,463 Answers
  • Posted on Apr 05, 2010
Barry Coates
Hotpoint Master
Level 3:
Answers
3463
Questions
Helped
1405843
Points
12766
Hi.
Remove top cover of washer.
Remove rear access panel.
Slacken off the motor fixing bolts, and pull motor towards drum top.
Fit belt round motor pulley first, and then feed it round the drum pulley from the rear of the washer.
Tighten motor bolts just enough to hold motor steady, and pull motor towardsa cabinet side to tension belt, it needs to be farly tight.
Then tighten motor bolts securely.
Fit back top and rear covers.
Testimonial: "Job done, excellent advice."
1helpful
Noisy bearings
ok, turn the nut at the back anti clockwise, i normally jam the pully into the cut outs in the drum, when you have taken off the nut hold the inner drum inside the outer drum and tap he pu;;y anti clockwise, not too hard or it will crack, remove pully, place nut flush with shaft on the thread and you will be ablt to tap the drum out without damaging the thread.
Just replaced jockey wheel on hotpoint aquarius ctd00 but drum still not going round??
Check belt not slipping, Most likly cause is motor brush assembly.About £18.00 to fix yourself
How to fit a belt to a hotpoint aquarius when the back cannot be removed
If there is a small inspection panel at the back where you can get to the motor remove that then remove the top lid of the machine. Loosen motor mounts and swing motor up and remove belt from motor. Now remove belt from pulley from the top of machine. Reverse the order starting from the top to replace belt.
Hotpoint Aquarius WMA32 - belt slipping off?
Probably it wasn't fitted properly. make sure the belt is tight when fitted, and at least 2 groves from either side at the motor shaft.
47helpful
2answers
Am trying to replace the belt on a hotpoint aquarius wf240 washing machine. I have removed the 2 bolts which appear to hold the motor in place ( 1 bolt on each side). However the motor still will not
Hi. The motor is non adjustable on this washer. Tilt washer forward, get someone to hold it steady, and put belt round motor pulley first, then slip belt on drum pulley, and slowly turn drum by hand, feeding the belt on as you turn drum, be careful not to trap fingers, as it is very tight, this is normal, as the belt is a stretch type, this is the reason the motor is non adjustable. Please rate my advice. Thanks.
WF340 hotpoint aquarius WASHINING MACHINE
Hi, Remove the drive belt from the drum & motor then turn the drum be hand, Is it noisy? if it is then the drum bearings need replacing i have used this website before and they are very good.
http://www.candmdomesticappliances.co.uk/section.php/88/1/hotpoint-washing-machine-spare-parts
1helpful
Need to replace drive belt on hotpoint wf430 but to tight to get
Put it on the motor spindle first then feed it onto pulley. It is tricky with such limited access.
Hope this helps &thanks for using Fixya.
The belt in my washing machine just broke
Try this number; 0818 313413
This is Hotpont service in Dublin.
Plz rate my soution.
Thanks.
Hotpoint Aquarius WM31 Washing Machine
The tripping can either be down to a short circuit drawing too much current and blowing the fuse , or an earth leakage blowing an RCD. You can eliminate the motor when it happen again , by unplugging it and see if the fuse blows (without turning the drum). Most likely is the heater , but i cannot explain why turning the drum allows it to continue. It is possible a wire is rubbing somewhere on the drum pulley , motor or casing. If the machine will immediately trip again if you don't move the drum , try isolating parts by disconnecting and then retrying.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
