Question about Ricoh Aficio SP C820DN Laser Printer
I have ricoh sp c820dn printer and it dosent work and i dont know how to use it with pc windows xp/sp2, please help me how to install it on my pc and how to use it
Posted by ahsh75 on
Dileswar Seth
    Sergeant:
  • 253 Answers
Pls put the printer driver on drive (cd) and clik on set up file,,than installed it
Posted on Apr 05, 2010
Sp c820dn laser Printer error sc561 problems???
Replace the fuser. Then thermopile if it continues.
Aug 10, 2014 | Ricoh Aficio SP C820DN Laser Printer
WINDOWS 7 DOESNOT RECOGNISE DOWNLOADED DRIVERS
Just downloading the driver won't fix anything. You need to install those drivers before they will work. look in C:\documents\downloads for the drivers.
Jan 12, 2014 | Ricoh Aficio SP C820DN Laser Printer
My new Ricoh C820DN printer gives me a "waiting
please DO NOT use PCL printer drivers. USE RPSC or PS (post script) drivers and everything will be OK
pifonski
Feb 24, 2011 | Ricoh Aficio SP C820DN Laser Printer
How to open front cover for ricoh aficio c820dn printer as it is displaying message " open the front cover to check the paper jam"
Hi there !
You have to open the front cover means that you have to oper the toner compartment and check for the paper jammed inside.
Did it helps your or you find the paper jammed.
Jan 29, 2011 | Ricoh Aficio SP C820DN Laser Printer
Sc582
tengo un problema con la maquina ricoh sp c820 el error es sc582
Sep 24, 2010 | Ricoh Aficio SP C820DN Laser Printer
Replaced a hp 8150 with a ricoh 8200. When
That is the way duplexing works. Both sides of the page are read into memory and then the second page prints followed by the first page after the paper turns around.
Turn you paper stack over so the the 2nd. page prints correctly on the page and the first page should be fine. If it does not, please let me know and we can take some steps to look at the data going to the printer.
Don
Mar 10, 2010 | Ricoh Aficio SP C820DN Laser Printer
Ricoh Aficio SP C820DN Laser Printer Logo
219 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
