Question about Amana ARB9058CS Bottom Freezer Refrigerator
I have an Amana BC20TW refrigerator with a bottom freezer. It seems to be running all the time. I raised the temperature dial to make it warmer and it still runs too much. Put velcro on the bottom freezer door to make sure it was securely shut and it still runs too much. I think I feel cool air coming from behind the refrigerator. What is going on? Please help.
richie46
    Top Expert:
  • Amana Master
  • 12,962 Answers
Accuracy is important --Use a digital thermometer to monitor freezer and fridge temps. Fridge should be around 40 and freezer around zero and then take it from there and draw conclusions
Posted on Sep 22, 2017
5 Related Answers
yalmer
Hjalmer Lamminen
  • 552 Answers
SOURCE: Amana Bottom Freezer control knob
http://amana.com
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
Posted on Mar 17, 2008
Techsim
James
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Robert Hirst
  • 833 Answers
SOURCE: temperature
Lower numbers are warmer temps.  Get an outdoor thermometer and put it in the fridge.  It should read about 40 degrees F if you've left the door closed for an hour or so.  Don't worry about the freezer too much.  It should be at 0 F or so.  Generally, leaving the settings at 2 or 3 is right on most units.
Posted on Nov 20, 2008
Fix-R-Up
  • 6 Answers
SOURCE: Amana 22 side-by-side refrigerator, freezer door opens slightly
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
Posted on Jan 01, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Too cold
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.
Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.
The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
Jul 26, 2012 | KitchenAid KBFS25EVMS Stainless Steel...
I have an Amana bottom freezer refrigerator model bc20tw that runs all the time. The freezer is cold but not enough to harden ice cream.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 10, 2011 | Refrigerators
I have a amana bc20tw fridge with bottom freezer that is keeping cold in the freezer and cool (43 degrees) in the fridge. I checked the coils in the freezer and there is no ice or major frost. Also, the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | Amana ABB1927DE Bottom Freezer...
Fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Mar 24, 2009 | Refrigerators
    FREON
    the backpressure or suction pressure varies with the load and the ambient temoerature of the unit. best way to make sure that your charge is correct is to pull refrigerant out and evacuate aand weight in new refrigerant with a scaloe.
    Jan 10, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
    Freezer not cold enough
    Begin by turning the freezer temperature setting dial to a lower setting. Then wait a few hours to see if your problem is fixed. If that does not correct the problem you probably need to have the coolant system recharged. That requires special equipment so you will have to call in a repair person.
    Dec 29, 2008 | Frigidaire FRT21H8 Top Freezer...
    Help, no water but have ice out of door on amana side by side.
    The freezer temperature dial is set too cold and it is causing the water to freeze in the tube right where it enters the freezer section.If you turn the temperature selector one or two numbers warmer for the freezer it will help.
    You will also have to turn the box off and let the freezer thaw real good so that the line will thaw. Once this has been done, it should work fine.
    Jun 08, 2008 | Amana SXD524VW Side by Side Refrigerator
    http://amana.com
    Mar 17, 2008 | Amana ARB8057CSL Bottom Freezer...
    Amana ARB9058CS Bottom Freezer Refrigerator Logo
    117 people viewed this question
    Top Amana Refrigerators Experts
    John Tripp
    John Tripp
    Marvin
    Marvin
    Colin Stickland
    Colin Stickland
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
