1290 error coming when stop a print the display this error massage
"system error 1290 please power on off"
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
ERRO 1290 ( MANUTENçãO PREVENTIVA DAS CORREIAS E DAS BOMBAS) na verdade isso é apenas para garantir que sua maquina fique sempre em perfeito estados dessas peças, SOLUçãO: DESLIGUE A MAQUINA, E LIGUE-A COM A TAMPA ABERTA, ELA LIGARA PERFEITAMENTE, MAIS NãO IMPRIMIRá, VAI DAR ERRO NA USB, VC TERá QUE ENTRA NO MODO DE SEGURANçA, ENTRANDO NO MODO DE SEGURANçA, BASTA PROCURA "COUNTER" NOS SERVIçOS E RESETAR ALL, OQUE ISSO FARA A MAQUINA TEM UM CONTADOR, QUE FAZ A CONTAGEM DO TEMPO DE USO DAS CORREIAS E DAS BOMBAS, QUANDO ESSA CONTAGEM CHEGA EM UM DETERMINADO VALOR ELA ACIONA ESSE ERRO 1290 POR SEGURANçA, LEMBRE-SE ISSO FARá SUA IMPRESSORA VOLTA A IMPRIMIR NORMALMENTE MAS PODERá PARA POR QUEBRA DA CORREIA (MUITO DIFíCIO DE OCORRE) OU POR LGUMA BOMBA PARA, MAIS ISSO SO ACARRETARA DA NAO LIMPEZAS DAS CABEçAS. MAIS O CERTE E FAZER A TROCA DESSAS PEçAS. ESPERO TER AJUDADO MSN: [email protected]
The 1290 error is a safety shutdown error.
It means your printer has been displaying the "Service Needed" message for some time now indicating that it needs a maintenance service where belts and hoses that will wear our over time need to be replaced.
In order to prevent these parts from failing and possibly doing extensive damage to your printer the printer has shut down until you get this service done.
You will need to call HP or an authorized service tech to get this maintenance done.
1170
1020 ???
Sensor clean
