Here you go...I hope this works for you....
CD/DVD Is Not Recognized
Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
DVD drives can read both DVD's and CD's.
CD-ROM drives can read only CD's.
If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
Clean the CD/DVD in the following manner:
Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
Try to use a different CD or DVD in the drive to see if that disc can be read.
If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
There are a number of possibllities for this problem:
1. Your drive may be dirty. Try to get a drive cleaner, run it then try again
2. The disc itself is faulty. Try using it on another computer's drive and see if you can read it
3. It is a region-specific DVD. Some movies can only be played on DVD's made for that region. Although you can change your DVD's region to be able to read that DVD, you will then not be able to read DVD's for your current region. The recommendation here is to buy a multi-region DVD player. You do not need to get the top of the line model as these players can be quite cheap.
NOTE: Please rate our help to keep this free service online.
First clean the CD/DVD head by cd/dvd cleaner. If that doesnt work then probably you will need to get its read write head aligned or get the drive changed totally.
1. this is usually due to the laser reader in the CD or DVD drive has failed or the disks are dirty or scratched. or the DVD drive isn't capable of reading the disks at a certain speed and need replacement . 2. of the DVD cable has become disconnected at the motherboard connection. 3.DVD drive may need replacement.
ITs a dvd rom drive. It will not burn blank dvds in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
