Question about Radica U B Funkeys Green Fallout Computer
UB Funkey installation errors - Windows 7 64 bit.
UB Funkey installation errors - Windows 7 64 bit. tried driver patch on mattel website, still no luck. Any suggetions to correct?
  • Anonymous Sep 08, 2010
    not a computer problem as this is a known issue with UB funkeys..Why would you not research this before you post something like you did?
Anonymous
    New Friend:
I have called mattel on this matter.
They said that Win7 64bit is currently not supported by ub funkeys software. sorry
Posted on Apr 05, 2010
Testimonial: "Thanks for investigating this!"
Andrew F.
  • 37 Answers
May have to go the old fashion route of right clicking the installer and going to properties. From there, click the compatibility tab and click the box that says, "Run this program in compatibility mode for".
Select "Windows XP sp3". This may be the only solution that may work.
I am running W7 and had to do that for a few of my older programs, so it may work.
Suuny Kohn
  • 808 Answers
Symptoms u have identifies are most probably linked to registry errors on ur computer it is wise to run? a registry repair scan with reg in out? registry cleaner...
Posted on Sep 08, 2010
  • Anonymous Sep 09, 2010
    you are not knowlegeable regarding this issue, why even contribute?
Canon printer scaning error 255,0,0 how it solve?
Driver releated issue. Please download latest version of your region from Canon website then Un install previous driver and install new version driver....
Nov 27, 2017 | Canon Office Equipment & Supplies
Error message saying I am missing microsoft version 2.0. Is there a bridge or patch to get the microsoft. I have tried to down load this version and I get a message saying I have a 32 bit map and it...
If you're using Windows 7, check if it's running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the links below to download the Lexmark Z2420 Printer Driver from the Lexmark website: - Lexmark Z2420 Driver for Windows XP/Vista 32-bit/Windows 7 32-bit - Lexmark Z2420 Driver for Vista 64-bit/Windows 7 64-bit
Aug 12, 2011 | Lexmark Z2420 Printer
Trying to install printmaster 95 on my windows 7. error message appears that it is non compatible with 64 bit. is ther a patch available to make pm 95 compatiable with 64 bit? any suggestions around...
Title: trying to install printmaster 95 on my windows 7. error message appears that it is non compatible with 64 bit. is ther a patch available to make pm 95 compatiable with 64 bit
First of all download compatiable driver for that printer for win 7and install it
May 08, 2011 | Computers & Internet
I have a scanmaigic 1200 ub plus scanner and I am trying to install it on Windows 7, I hit the autorun to install the disc but nothing happens.
The Mustek Plug-n-Scan 1200 UB Plus is a legacy to Windows Vista and 7. The driver's are limited to what the manufacturer's website can provide. Microsoft also tells us that it is not compatible with Windows Vista or 7. You may check out Mustek's website. It can only work for the following Windows versions:
It's either you (1)upgrade for a new scanner, (2)downgrade Windows version of your computer, or (3)use the scanner with a computer with Windows XP in it.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Is there installation software for Windows 7
according with Windows 7 compatibility Center isn't a windows 7 supported. The manufacturer is yet to write MUSTEK Scanexpress 1200 UB Scanner drivers for Windows 7. Click here to verify http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=MUSTEK%20ScanExpress%201200%20UB%20Scanner&v=MUSTEK&uid=&l=en-US&pf=0&pi=0&s=Mustek%201200%20UB%20plus&os=64-bit
However, you could try downloading MUSTEK Scanexpress 1200 UB Scanner drivers for Windows Xp and try running them in compatibility mode. click here how to run them in compatibility mode y all this does not work you must have to contact manufacture for better support. hope this help
Jan 20, 2011 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Every time i try to start ub funkeys i get an error message that says "error occurred at application start". Tried reloading and installing the patch, rebooting all to no avail
ub funkeys needs Adobe flash player installed, it could be your problem. It seems not a software itself problem since you have tried installing it several times.
HAve you tried in another PC? Which O.S. do you have?
Funkeys dont work under Windows seven, the software was developed for XP and there is no drivers for W7.
Jan 22, 2010 | Radica U B Funkeys Green Fallout Computer
1248 ub driver for windows 7
1-Mustek Scanner 1248 UB driver for windows 7 (32 bit)
2-Epox Blueetooth BT-DG07A driver for winows 7 (32 bit)
Jan 16, 2010 | Home Fencing
I have a UB FUNKEYS software and i could not have it installed for my son.is there a way to find a driver for this game? please help
If you mean the original disk you purchase with your HUB (big white funkey), it must work, I don't know what's happening , maybe the disk is damaged. I have a question, which O.S. are we talking of?
Funkeys only work on Windows XP, period.
You can reach me at [email protected] if you have more questions and maybe I can help you.
Sep 07, 2009 | Intel Computers & Internet
Ub funkey hub won't connect
you can go at "compatibility" and choose Windows Vista or Windows XP. but this is not helping for running the game... only installation worked after that.
Now I try the Adobe flash player thing...
greez,
Lanthira
Apr 21, 2009 | Radica U B Funkeys Green Fallout Computer
Drivers for Mustek 1200 UB Plus for Vista 64b
I have a Mustek Plug-n-Scan 1200 UB Scanner. I can't still install it under Windows Vista 64 bit.
Feb 03, 2009 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Radica U B Funkeys Green Fallout Computer Logo
13,006 people viewed this question
Top Radica Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Radica Toy Expert? Answer questions, earn points and help others
