SOURCE: how do i turn my
there is a button near to the DVD rom tray...you can slide it to activate wireless..
SOURCE: Dell Inspiron E1705 Do I have a switch or
you should have software that came with Dell but failing that you can use Windows by clicking connect to on the Start Menu
SOURCE: CANNOT CONNECT WIRELESS MOUSE TO DELL INSPIRON 1525
this is a bluetooth mouse, if you have used it before then you'll need to remember how to sync it with your computer ( you should have some sort of bluetooth manager window that will be able to find the moue and communicate with it.
If you haven't used it before you might not have bluetooth built into that computer ( i have an inspiron 1525 and i don't )in which case you'll need to buy a bluetooth dongle which will plug into your USB port and will communicate with the mouse for you. The dongles are pretty cheap though, here is a link to one for 2.54$
http://www.dealextreme.com/details.dx/sku.11866
SOURCE: How do I turn on wireless capabilities for a Dell Inspiron 1525?
I had the same problem, but I solved it by hitting the f2 key alone (w/out the function key). when i keyed them at the same time the wireless did not toggle on/off
here is the answer... (For Vista)
Go to the icon at the bottom right yellow/blue arrows (Dell Quickset) Open it.
Then go WiFi Catcher/radio controls (click it to open it).
Then go to "advanced settings" at the bottom of the pop up (open it - click it).
Then select the TAB "Radio Control Options"
Then UN-check all the radios and wifi, then apply, then OK. Your green bars should work now...
