Polaroid 1913TDXB 19 in. LCD TV/DVD Combo Logo
Posted on Apr 04, 2010
Polaroid 1913- TDXB, turns on, comes up to Polaroid logo, might even get to channel selected, shows picture and sound, then screen goes black. Turn off, repeat, approximately 5-7 seconds. Is the inverter my problem and is there a known component(s) I should be looking for such as bad caps?
5 Related Answers
rusellk
  • Posted on Dec 03, 2008
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Anonymous
  • 3 Answers
  • Posted on May 15, 2009
SOURCE: Remote codes
what you need to do is call direct tv support they should have a code for you
Anonymous
  • 6 Answers
  • Posted on Aug 05, 2009
SOURCE: Screen goes black after couple seconds on my Polaroid 42" LCD
I had a TLX-4240B 42" Polaroid LCD TV and the screen would go black after about 10 minutes. There was still sound. I removed the two covers exposing the circuit boards behind the TV. I powered up the TV and waited for the screen to go black (I was going to start trying to pinpoint where the issue was with my trusting meter) then noticed a red light would come on when the screen would go black. there were 4 mini switches right above the red light. I switched the one that said burn and the TV has been working great since. good luck and let me know!
Rakesh Kumar
  • 296 Answers
  • Posted on Aug 13, 2009
SOURCE: need manual for polaroid 1913tdxb
Hi, Please visit this link http://safemanuals.com/user-guide-instructions-owner-manual/POLAROID/1913-TDXB-_E you will get the manual
Thanks! mannu_rakesh
Chi Chu
  • 8457 Answers
  • Posted on Nov 03, 2009
SOURCE: I have a Polaroid 1913 TDXB with the original
Take the remote aparts,clean it with a Q tip with some rubbing alcahol.Clean the rubbers films and the circuits board.Clean IR in the tv and the remote.After this still don't work ur remote it dead,by the main CPU,it junk know.Here a website to buy a new one 1-800-Remotes Factory original.Never have need codes for oiginal remotes.
Polaroid tv model number 1913 tdxb screen goes black after a min or less
I dont see an LED back lights listed for that unit. This means it uses CFL lights. The link I am posting for this is a major parts supplier, as you can see the power supply for the back light is out of stock, you can use the info there to get the OEM part number and then search for it on ebay etc. Good luck because the unit is obsolete and you may end up having to get the board repaired. https://www.shopjimmy.com/catalogsearch/result/?q=1913+tdxb+
Pretty much my 19 inch polaroid turns on then goes blank
Might be your backlight inverter...do you have sound? If so, hold a flashlight up to the screen when it's turned on and if you see images...that is probably the culprit. Try these guys for parts, they have been great to me in the past....ShopJimmy.com.
[email protected]
http://www.shopjimmy.com/catalogsearch/result/?q=1913-TDXB
Video display will stop after the TV is running for a few minutes. Audio is fine, video goes black. Model 1913-tdxb, June 2007
The tv Long LCD inverter board it is dead.This long LCD inverter provide a backlight for the tv LCD screen panel to have a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a reburbish a long LCD inverter board for the replacement.
Need a power supply for my polaroid lcd tv model 1913-TDXB
Hello
You need to contact nearest Polaroid Service Center to replace the power supply or contact the Product Support Here
http://store.polaroid.com/support_detail?p=4116
Good Luck
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Black out
Try turning off the Closed Caption..
2answers
Polaroid 19" TV TLA-01911C has no picture. Powers up, see logo
I had the same problem. I replaced 14 capacitors on the Power supply board. I used Panasonic FC series. You could look for swollen capacitors or ones that are oozing. For sure replace these. My set had capacitors that are known to cause problems so I replaced all of them even though I saw no swelling of oozing. Be sure you label all connections carefully when you disassemble.
Polaroid 1913-TDXB 19" LCD HDTV/DVD Player Combo no longer recognizes dvds
I have the same TV and the same thing happenned. Then after a month or so after DVD stopped working I get not picture at all. TV is shot.
Polaroid flm373b
Try several different inputs.
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
